Question about JVC PC-XC12 Boombox
The sound seems to be distorded on my systems what are the setting for the sound so it can be back it way it was cheers ger
The sound seems to be strange or the bass isnt working correctly its doesn sound as good anymore, i need the settings so i can change it back to the way it was, and i dont know what the bass treble should be
bluenadas
  • 203 Answers
SOURCE: Sounds but no bass
Check your setting for the sub first. If that doesn't pan out it is likely to be the amp.
Posted on Jun 15, 2007
Tech4lfe
  • 42 Answers
SOURCE: Volume wont work
In the menu for initial setup look for a setting for center channel and turn it off. If it is on you will have no sound because it turns the TV speaker into the center speaker for a surrond sound receiver input.
Posted on Jun 27, 2008
SOURCE: How do i set the time on my JVC KD-G320
press and hold sel button for a few seconds untill it shows demo, release and press right or left arrows untill it shows time hours or minutes, turn volume knob to set time and press sel button to set
Posted on Jul 31, 2008
Hazardsneon
  • 100 Answers
SOURCE: jvc car stereo 45wx4 kd
My bet is that the reason you loose the setting every time the key is turned off is because you have no constant power going to your yellow wire. With the power on major brands of cd players there are 3 "power" wires. One is black which is ground, one is red which is the accessory power, this is only on when the car is on, and the last one is the yellow which is constant which stays on all the time so that your cd player can keep settings. Good luck. Let me know if you need more help.
-Andrew Hawkins
Posted on Sep 04, 2008
dunnbiker
  • 8546 Answers
SOURCE: Because my rear speakers are
Cracks and pops are dangerous. Can you tell if they might be circuit overloads or maybe digital decoding errors?
Are you routing bass to small speakers. THAT would definitely have audible problems. Define all of your speakers Large vs Small based on their bass-handling capacity.
ONLY DTS? Probably NOT the speakers or amps. How many sources are involved? Could be with the source or cabling.
Does it happen at low volumes, too? Then it would probably be digital in origin.
Do the indicators various digital surround mode indicators flicker or turn off when the pops appear?
As for the rest of your questions, I'd set everything at flat and start all over. If you're maxxing out any settings, something is wrong.
Posted on Jan 04, 2011
Bad noise problem
This sound related to fuser driving gers, if these geras are warn out this type of grinding sound will generates.. These gears atr located left side of fuser bank..
How to reach: Remove back door,un screw 4 screws of fuser & detach three connectors, take out fuser you can see the left end,, pl se the snap shot, replace these gears, if not avail total gers atlest replace 4th T20 grat shown in fig.. For giving better life to these gears apply greese for thses..
Feb 06, 2012 | HP LaserJet 2420 Printer
My printer work but with bad sound
Top of the picture is black and the other half is distorded
sounds like its time to trade it in as the repair will cost more than a new set
Oct 13, 2011 | Philips TP3675C 36" TV
Distorded sound when you play thru it . when the signal input is low . when you tap on the speaker it barks like some thing is loose inside
Some SRM power amp resistor has a broken leg and it has an intermittent contact, let me know furthermore.
Sep 08, 2011 | Mackie SRM-450 System
I reinstalled windows 2000 because I kept getting the dreaded blue screen, and It seems to work, but my screen and Icons are ugly, and distorded. Is there a fix for this. I have all the cd's for reinstall.
It sounds like a graphics card driver issue. You may find one if you do a windows update, if not go to the card manufacturer's website for an updated driver.
Aug 18, 2009 | Dell Computers & Internet
Just installed new 23" Acer monitor but can't the the setting to work properly. The Icons seem distorded and it seems to cause a printing problem
Hi..
You need to install the driver fo your motherboard to fix the video graphix, that why the icons are so big
Regards
PCmania
Jul 07, 2009 | Computers & Internet
Ilo 42 plasma
if it made a sound like that, this is a most likely non-user-serviceable physical problem. now would be a good time to use your warranty if you will have it.
Dec 29, 2008 | iLO 3200 32 in. LCD Television
Fuji fine pix s9500
you can look through all menu to see if default setting is present. if not set up this way. look through menu 1 hit the arrow keys or ger to next....any ways set Iso to auto. focus to auto flash = auto metering to multipoint most important see if shutter speed has an auto or set to 1/8 second or 1/1000th hope this helps you ...but your going to have to read the manual some day. good luck
Sep 01, 2007 | Fuji FinePix S9500 Zoom Digital Camera
I cannot hear my sound if i call
u have headphone socket problem change ur phone charging base problem will solved charging base is to bottome of ur phone
Aug 13, 2007 | Nokia 1100
JVC PC-XC12 Boombox Logo
16 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
