MP3 player guide MP3774
When I try and follow instructions of p.10 of manuel step four drive named "removable disk" or "MP3 player is suppose to come up. Doesn't. closest thing is "Devices with removable storage" Is that the same.?
I also "ripped" CD to "my music" followed tdhat down load and shows down loaded and how many GB's used, but no music on MP player.
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Turns out the problem was not with the download, that had been acccomplished, but with the MP3 player. Problem solved.
Posted on Nov 11, 2008
My freestyle player says format error how to fix?? it was working fine and then this error.
Hello there,
Q.: My player is having a DRM error / Format Error / Empty Disk Error
what do I do?
A: For all 3 errors, the first step is to attempt to reset the player, this can be accomplished by pressing the play and menu
buttons down together for approximately five seconds. If reset does nothing, make sure all the songs are .mp3s, if all songs
are .mp3s, attempt to format and re-sync the player.
if you need it
How do I convert my iTunes into MP3 format?
A: See Music Conversion Instruction Document: Transferring and Playing Music on Freestyle Audio mp3 players with
iTunes.
if you need to format the player here is how for MAC and windows.
Q.: What's Reformatting, How do I format my Player?
A: Reformatting your player basically wipes you player clean and deletes all songs, leaving you with a blank slate. Like
most removable drives you can reformat your player with no worries of damage to the unit. When reformatting on a Mac
make sure you choose the MS-DOS format style.
(CAUTION: FORMATTING WILL ERASE EVERTHING ON THE DRIVE)
PC (Windows NT, 9x, XP and Vista):
1. Plug in the Mp3 Player.
2. Put the Player in removable drive mode. Under "My Computer" you should
see the player as a removable drive.
3. Right click on the "removable drive" and a Drop down menu should appear.
4. In the menu select the option "format..."
5. Make sure that "FAT" is selected as the file system and that Allocation
Unit size is set to "Default Allocation Unit Size"
6. Now click format and wait, after it says format complete, you're done.
MAC OS 9 (and Earlier):
1. Plug the player in.
2. Put the player in removable drive mode.
3. Single-click the disk's icon on your desktop to format.
4. Pull down the "Special" menu from the top of the screen and select "Erase
Disk..."
5. Enter whatever name you want in the "Name:" field in the window that pops
up. If the disk is a hard drive, select "Mac OS Extended" from the
"Format:" pull down. If the disk is not a hard drive (such as a Zip Disk
or other removable media), select "MS-DOS or MAC OS Standard" for the
format.
6. Press "Erase." The drive will be formatted and ready to use.
MAC OS X (and later):
1. Start your computer and plug in the player in the USB port after the Mac
OS has completed loading.
3. An icon for a removable drive should appear for the flash drive on the
desktop.
4. From the Dock, open "Disk Utility".
5. Click "Erase" from the top selector (next to "First Aid")
6. Choose "MS DOS File System (FAT16)"
7. Click the "Erase" button
8. Perform the instructions given on the screen and finish the formatting.
if you need any help with a Step let me know and i hope this information was helpful don't forget to Rate .
Jan 27, 2011 | Freestyle Audio MP3 Player
Need to remove hard drive
his document provides instructions for the removal and replacement of the hard drive for the R3000, R3100, R3200, R3300, ZV5000 and ZV5200 series notebook PCs.
Use the video as a guide while following the written instructions below.
To view the video press the Play button on the player control bar below the video.
To stop the video press the Pause button on the player control bar below the video.
To restart the video press the Rewind button on the player control bar below the video.
NOTE:Flash Player from Macromedia is required to view this video. Visit the Macromedia website (in English) to download and install Flash Player.
Step 1 - Remove the battery
Slide and hold the battery release latch to the unlock position.
Use your finger to lift the battery up and out.
Step 2 - Remove the hard disk drive
Remove the two Phillips-head screws that secure the hard disk drive to the base enclosure.
Lift the inside edge of the hard disk drive to unseat the hard disk drive connector from the system board.
Remove the four Phillips-head screws that secure the hard disk drive to the hard disk drive bracket.
Remove the hard disk drive from the hard disk drive bracket.
Pull the hard disk drive out of the bay.
Place the hard disk drive in a static dissipative bag.
Dec 05, 2010 | HP Pavilion ze4300 Notebook
My iball 4gb pendrive suddenly stop working. but my pc detect it as a removable disk instead of my drive name.when i clik the reemovable disk it gives a msg "please insedisk into drive"G". also the light...
Try to format it and see if the same error happens:
follow these steps below
To format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system or the file system you are used to.
hope this help you
Regards
uttam
Jan 13, 2010 | Transcend T.sonic 612 MP3 Player
I dont have a disk or manuel for my sandisk sansa m240 how can i download music to it? I have the usb cord tho.
Follow these steps to drag-and-drop music files to your Sansa player:
1. Connect your Sansa player to your computer.
2. Open Windows Explorer.
3. Double-click on your Sansa player.
4. Double-click Internal Memory if you are using WMP 11 or double-click
Media if you are using WMP 10.
5. Drag and drop music files from your computer to the Sansa player’s MUSIC
folder.
Dec 10, 2008 | SanDisk Sansa m240 MP3 Player
How do you format the ilo mp3 player
This is a common problem with these units. Try this:
To Format your player follow the following steps:
PLEASE MAKE SURE YOUR ILO IS DISCONNECTED FROM THE COMPUTER BEFORE
BEGINNING!
1. Open up your My Computer Icon to show your drives installed on
your computer and take note which ones are installed. Leave this window
open.
2. Connect your ILO device and wait for the two additional
"removable disk drive"(s) to appear in your My Computer window (ex:
removable disk drive [E:], removable disk drive [F:])
3. Right click the first drive that appears (ex: [e:] if the
removable drives show as [e:] and [f:]) and select format
4. Click "start" on the format window
5. Disregard the warning notice that pops up
6. Once that is complete retransfer all of your music and then
your device should function properly.
There are a select few mp3 players that are having a few issues with
the internal flash memory and will not allow windows to format it. The
only solution to these units is to reinstall the firmware into the
player itself. To reinstall the firmware, please search your email
folders for the email I have sent you titled "ILO 116 Firmware".
Sometimes, your email security settings will move this email to your
junk mailbox. Once you open the file, read the instructions and click
on the attachments link to open the software.
Hope this was helpful, have a great day!
Oct 30, 2008 | iLO (2 GB) MP3 Player
Pictures/Music Videos.
For pictures:
Turn on MP3 player, goto settings, make sure USB Mode is set to MSC.
Connect to Computer, go to start, > my computer > double click removable disk drive > in the removable disk drive, should be a folder labeled PHOTODIR, drag all your photos to this, they have to be JPEG.
For Videos:
Its a little more difficult, I've included the link for a setup guide, at the bottom of the guide is step by step on how to do the video conversion:
http://http.vitalstreamcdn.com/cobyelectronics_vitalstream_com/setupguide/MPC7095_SG.pdf
Aug 20, 2008 | Coby MP-C7085 MP3 Player
LOCKED MY SELF OUT OF WINDOWS VISTA !!!
There is a way to reset windows password without erasing anything.
Follow the instructions:
1.Free download the iso file : http://www.resetwindowspassword.com
2.Burn it to a disk to create the boot disk, that simple.
3.Configure your pc or laptop to boot in the cd drive,
4.Insert the CD, reboot from CD drive, and then just follow the process of instruction. A few steps later, admin password would be cleared
Took about 5 minutes for the whole process.
Oct 22, 2007 | Terapin Mine TX2000 10 GB MP3 Player
MP3 PLAYER PROBLEM
Go into control panel, find your network connections diagram, click on the USB that is connecting your player and note the lettered drive, this is where you will send the files.
 I bypassed Windows XP and went for VISTA as it has the compatability tool for syncing older programs with these newer ones. My daughter is running XP so I'll call her tomorrow and get back to you if she has some info to help, her husband does most of the music downloads for their family, I'll check with him also.
 I'm fairly certain your 'player disk tool will be found in your system tray of programs. Find it open it with windows explorer to see if what you need is there. Connect your player, check that in control panel it shows up as connected, and try a download. With my new one I had to dig into what was on the disk with administrator authority to find the correct driver for the formatting of the disk and the logs; like phonebook, contacts. They were all written for anything XP or before, so I had fun. Good Luck, Walneta
Sep 05, 2007 | Audio Players & Recorders
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
