Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Resetting a sony television to receive digital programs
I have a Sony KD28 DX50U digitally intigrated TV and after the transmitters were modified I tried to retune the digital programs, this wiped them all off and it will now not reload. I believe the set can be manually reset so that I can once again receive digital chanels after receiving an update through my tv ariel. can this be done easily and if so how? Hoping for some help,
  • 1,653 Answers
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
Posted on Oct 03, 2009
With Sony KP-46WT520 46 in. Rear Projection HDTV-Ready Television, does it receive digital signal over air? Do I need the separate digital converter box? What do I hook up where to get channels? and how do...
Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
Jan 13, 2018 | Sony KP-46WT520 46" Rear Projection...
How can i connect my 32" sony bravia?because the
Route the television audio directly through a stereo receiver. Connect the audio outputs of the television to the audio inputs of the receiver, using digital (coaxial or optical) or RCA (left and right audio) cables. Connect the left and right stereo speaker to the corresponding terminals on the receiver. Be sure that the positive and negative terminals of each speaker and the receiver are correctly lined up
Use a cable box. If your television doesn't have audio outputs, as many older TVs don't, use the outputs from a cable box to route your sound to the receiver. Proceed with a digital or RCA connection as described for the TV
Use a VCR. If you don't have a cable box, run the cable from the wall outlet into your VCR and then instead of outputting the audio to the TV, output it to the receiver so that you'll get sound from cable programming through the receiver and to the speakers, rather than to the TV. Connect the video output from the VCR directly to the TV for the easiest setup. You will then need to control your television programming with the VCR.
Change the program mode on the receiver to the input category you used to input the audio; for example, "TV," "Cable" or "Aux" are common options. You should now be able to hear audio from television programs on your speakers.
Mar 01, 2011 | Durabrand 5.1 Surround Sound Computer...
Do i need digital converter box for my KV-32FS120 Sony Wega made in 2005?
You will need a digital receiver box to have digital on this television.
Feb 01, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi! just need to know if my tv is ready for digital tv i have the sony kp-57ws520. i've hooked up my antenna and i still dont get a picture thanks for any info.
Your Sony KP-57WS520 television has an analog tuner, so you may need a digital tuner or a converter box to continue to receive over-the-air programming.
If you subscribe to a cable or satellite service, your television viewing should not be affected by the June 12, 2009, cut-off date for full-power analog broadcasting. Please contact your service provider for complete information.
Go here for more info:
Jul 07, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony KDF-E42A10 42" - Do I have to purchase a converter box?
Yes this tv does have a digital tuner. To engage it, you must have a out doors antenna. Go to channel setup and do auto program for both anolog and digital. link
Jan 13, 2009 | Sony KDF-E42A10 42 in. LCD Television
I have lost digital ITV and all the digital stations on my Sony Bravia.
Perform a master reset by doing the following:
Turn the TV On
With the original Sony remote, hold down the "up" button in the 4 direction buttons (uo, down, left, right)
While holding down the up button on the remote, press the power button on the TV (not the one on the remote)
The TV should reset and restart, asking you which language you wish to use.
After choosing the language, let the TV do an auto program and you should be OK
Please rate this solution. Thanks!
Nov 01, 2008 | Sony BRAVIA KDL52XBR2 Television
After power on my Sony bravia it goes to Digital
While tv in On position, select AV1, push power button to standy, then unplug tv for 5 minuts. check the out come.
Aug 03, 2008 | Sony BRAVIA KDL-46V3000 Television
Sony Blinking
It sounds like it is trying to start but is unable to.
these sets have bad horizontal output transformers.
you need a tech to solve this one.
Thanks Guy9
Jun 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Dec 27, 2007 | Sony QUALIA 005 46 in. LCD Television
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
319 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
