Question about Toshiba REGZA 47WLG66 47 in. HD-Ready LCD Television
Toshiba 47WL T66
There are verticial lines on the screen in various place but the one in the center is getting wider and looks like some sort off stain on the picture.
these lines are not visible when tv is switched off or in ble screen mode.
lines have been there but very faint since tv purchased in january 2007 and at first there was only two which appeared in the approx position off 4:3 picture.
Have been told it is an inherent fault and that the panel needs to be replaced.
  • 10,594 Answers
Correct, its problem of LCD Panel and will be replaced.
No alternate solution for vertical or horizontal lines in LCD Panels.
Posted on Nov 10, 2008
SOURCE:
My screen is cut off at both ends picture is stretched out
You could be in overscan mode. There might be a video button on the remote that allows switching between the various video output mode.
Oct 28, 2014 | Samsung Un55d6000 55 Inch 1080p Led Hdtv
Vertical lines
You have done a replacement to its main board, and power board, I assume. After replacement of main board, there is some critical adjustments should be done. A sort of software update or so. Contact any experienced service technician, or, the authorized service center for Toshiba.
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCDs are shown in illustrations. Check it, and take your own determination.
Jan 10, 2014 | Toshiba 46" SL417U LED-LCD HDTV, 120Hz
I turned on my toshiba satellite and the screen is lengthened wider how do i fix it?
If you are using Win7, you failed to mention OS, right click the desktop in a open area and click on Personalize, you will find Display settings and , From your statment/question, I don't have much info, If it's your Desktop that's " lengthened wider", look in Desktop Background. I don't know what's on your desktop.
Nov 22, 2012 | Toshiba Computers & Internet
How do i fix the lines on my toshiba satellite laptop l25-s121?
More than likely the screen. The inverter normally causes things on the desktop to be barely visible. The whole screen looks black, but with a flashlight you can see the images are there when the inverter is bad.
Mar 22, 2012 | Toshiba Satellite L25-S121 Notebook
Thin and wide white lines on screen
Yes, your screen most likely is going bad, the only other reason for lines and distortion is a loose data cable that runs up the back of the lcd panel on the left side. For the touchpad, go to the control panel > Mouse > look at the top of the window and look for the device properties. open this tab and look for your touchpad listed. Highlight it and click on the settings button. Go through these settings and make sure that tapping is enabled. Even if it is, you may consider updating the drivers for the touchpad.
Jan 18, 2010 | Compaq NC8000 Notebook
Toshiba Regza 42R530U Overheating?
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc. http://www.abctay.com/
Oct 16, 2017 | Televison & Video
Vertical line down the center, sound OK.
This is the deal. Your picture tube is going out. How thick is the line. As it gets wider that will tell you how much more time you have. Was the TV dropped? There is a way to adjust this but you have to get into the back of the TV and if the static discharge is not done properly it will kill you. Don't mess with it. It is now cheaper to buy another TV on craigslist or your local paper than trying to repair it. Hope this helps.
JimmyC
Sep 25, 2009 | Televison & Video
61 in dlp has lines on tv
I have a DLP Samsung 61 inch. It has verticial curved wave lines, these lines seem to move. like it's not on the station good. (These lines are not black, but almost white in color.) All my other TV's in the same house, using the same sat. dish have good pictures. Could you tell me my problem and what part to look for. Thanks
Jul 21, 2009 | Samsung HL-P6163W 61" TV
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Toshiba REGZA 47WLG66 47 in. HD-Ready LCD Television Logo
349 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
