Question about HP Photosmart C6180 All-In-One InkJet Printer
Copying a document to Word
When I select the copier menu, I do not see a choice for copying the document to Word although I know I have used that feature in the past.
  • 345 Answers
If you used to be able to scan to a word document, sometimes a reinstall of the printer drivers will help this problem.
Posted on Nov 10, 2008
What do you mean by "stack copies" in brother
Sorting copies using the ADF
You can sort multiple copies. Pages will be
stacked in the order (1, 2, 3), (1, 2, 3)
and so on.
1 Press (Copy) to illuminate it in
green.
2 Load your document.
3 Use the dial pad to enter the number of
copies you want (up to 99).
4 Press Options and ? or ? to select
Stack/Sort.
Press Menu/Set.
5 Press ? or ? to select Sort.
Press Menu/Set.
6 Press Start.
Jun 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
I have a vtech dect 6.0 and i can not get this phone to ring. i do not know how to turn the volume up.
Press MENU/SELECT in idle mode to bring up the menu. Use up/down to select "SETUP HS" and press MENU/SELECT. Use up/down to select "RING VOLUME" and press MENU/SELECT. Press up/down to hear the choices and set the desired one by pressing MENU/SELECT.
Full instructions are on page 9 of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/85/UserManual/245/6041_Manual.pdf
May 09, 2011 | Vtech Cordless 6041 Phone
How do you retrieve the old faxes? The paper wasnt in the right feed and a bunch of faxes came in and it never got through. I need to retrieve it.
? Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [{] or [}] to select , then press [Start/Copy].
3 Use [{] or [}] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Jan 31, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
When I attempt to copy a document-8in. X 11in- and have the copy menu set to -"original size auto detect,the printer persistently prints a smaller document size,usually 4" X 5". I have...
Try to reset your Lexmark X4650 settings to factory defaults. On the printer operator panel, press Setup -> select Defaults -> select Set Default -> select Use Factory -> press OK. Then try to make a copy again.
I hope this information has been helpful. Thanks.
Jan 06, 2011 | Lexmark X4690 Wireless InkJet Printer
How do i change to get copied document to appear
There are 3 settings for print quality on the front panel, good, better, and best. Also when it is set on copy you press the menu button and scroll thru the choices and you will find a contrast setting that you can scroll to a lighter setting.
Jan 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
Minolta Dialta Di 350f how do you change the display language
1. User's Choice Function Setting Procedure
<Procedure>
1. Press the Utility key.
2. Touch the “User’s Choice” key.
3. Select the appropriate screen from the menu.
4. Select the appropriate function.
5. After the settings are complete, touch the “Enter” key to validate the settings.
2. User's Choice Function Tree
Memory Recall
User’s Choice 1/6 Mixed Original Detection
Language Selected **************** SEE THIS ONE
Original Copy Default
Auto Paper/Auto Size
User’s Choice 2/6 Drawer Priority
Special Paper
Multiple-in-1 and Booklet Copy
Zoom
Auto Panel Reset
Energy Save Mode
User’s Choice Mode User’s Choice 3/6 Plug-In Counter,ID Key Reset
Auto Power Off
LCD Back-light Off
4in1 Copy Order
Density Priority
User’s Choice 4/6 Default Copy Output Levels
Priority Density
Output Priority
Intelligent Sorting
Output Tray
User’s Choice 5/6 “Small” Originals
Scanner Dry
User’s Choice 6/6 Density (ADF only)
May 26, 2009 | Konica Minolta Office Equipment & Supplies
I need to get a copy of a document that I faxed.
No, the JOURNALS will only tell you the fax number it was sent to.
Feb 13, 2009 | HP LaserJet 3330 All-In-One Printer
Printer only printing 1 copy
make sure that you are using the correct print drivers
Sep 03, 2008 | HP LaserJet 2420 Printer
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
