Question about Amana ALW480DA Top Load Washer
Belt replacement amana lwa50al washer
Instructions on how to replace this belt
Instructions on how to change belt
Posted on Nov 10, 2008
Belt broke don't know how it went on where can I get diagram for amana alw880qaw
Posted on Mar 22, 2009
Amana washer stops running just before rinse cycle,sometimes if i take the dial back around it will work. is the timer shot or could it be something cheaper?!
open the timer and look for burnt contacts . if there are any replace it or buy a new machine .it replaceing take a couple photos of the wiring first so you know which goes where
Mar 15, 2015 | Amana Washing Machines
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Diagram with replacement belt doesn't seem to match old manual
I haven't worked on a belt drive but here is the Sears parts site for your washer with diagrams of the console, drive system etc. You may get a better idea of how to replace the belt from these.
Here also is the Whirlpool / Amana installation and maintenance document for Amana belt drive washers. It may look similar to yours.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56310258b0952a4e8525729c0056d75b/$FILE/Amana_Searcy_TL_Washer.pdf
The other thing I'd check is Whirlpools list of documentation for their laundry products. Check some of the washers that they make for one that looks like yours and you should get a better idea.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1&Count=30&Expand=6#6
Oct 08, 2009 | Kenmore Washing Machines
Replace Broken Belt
Here is the link that will explain how to do it:
http://www.applianceaid.com/amana-wash.html#belt
check this link u ll get if u dint really sorry for in convinience
Jun 17, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Remove front panal
Hi, there are two screws at the bottom of the front panel. THis should release the panel by ulling the bottom toward you. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Amana LWA40A
AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Amana ALW480DA Top Load Washer Logo
1,238 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
