Error Codes CANON IR6800 We can't figure out what they are
Good morning, I hope you guys can help me, I have 2 companies and no one can find the problem. I have several Canon IR6800's 1 of them is showing an error code of E000008-0001 and the other is showing a code of E000013-0001 and they are both locked up with these codes. Does anyone know what these codes are and how to possibly fix them? I could really use the help.
Sincerely,
Ignacio E. Montero
  • Anonymous Dec 07, 2008
    any set up to sent fax out, having problem with receiving from email , only 3 out of 15 received, what guildline for TX input ?
    canon ir6800
E000079-001
Posted on Jun 22, 2009
Errorcode canon irc6800 E000747-0001
Posted on Jul 06, 2009
Good morning, I hope you guys can help me, I have 2 companies and no one can find the problem. I have several Canon IR6800's 1 of them is showing an error code of E000051-0002 locked up with these codes. Does anyone know what these codes are and how to possibly fix them? I could really use the help.
Posted on May 01, 2010
E000012-0001
Posted on Nov 20, 2009
  • 1,326 Answers
Most likely, the E013 code is that the waste toner screw in the drum unit is pack with toner and the feed screw has gotten bound up..... It is also refered to as the AP-Unit. .. Checkitright is correct on the problem.... But for that to occur the whole waste toner tube is bound up. It is a very dirty and labor intence job to repair, I hope you have a contract on your copier. Or I hope you are not that attached to it..The problem needs to be repaired before it can be reset
The E0008-001, has nothing to do with the fixing film, it dose not have one & that model dose not use fusing oil, it only has a cleaning web and that will give you a E005. Are you sure on the error code? I did not find anything on it. Have you had a power problem? I saw something about a auto shut off pcb. Did you have this problem before or after a tech was there. The only thing that I can think of is a problem with DC controler or the counter pcb or the reader pcb.... I'll have to get back on you with that info..
Posted on Nov 12, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
E007 The fixing film is off to the side. E008 A specific number of copies are made after the machine detects that fixing oil is out. Since a user cannot re-supply fixing oil, the error code is indicated.
Check the fuser, either the film is off to the side or it is torn
or the oil is out (usually silicone oil) needs to be replaced
E013 •The PLL lock is released because waste toner motor is locked up, etc.
•The micro switch employed to detect clogging of waste toner is activated.
•The waste toner case is detected full.
Check the waste toner container, if full empty, other wise the waste toner drive system located on the drum needs to be cleaned out.
Posted on Nov 11, 2008
Error e00000100
Posted on Dec 03, 2009
The machine (canon ir6800) has been stopped and show error code E000013-0002
Posted on Mar 29, 2012
Canon image RUNNER 6055 Copier error E 000013-0002
Posted on Jul 06, 2012
My Canon Printer starts developing a problem. I am not good with printers so can someone help me diagnose it and resolve the problem?
Hi
go to Canon website and type in something like 'Support code XXXX' (substitute your printer model for XXXX) in the Search block. It should then point you to a page with your printer model support codes, explanations what each code means and what you can do to fix it.
good luck
Sep 19, 2014 | Office Equipment & Supplies
Canon Image Runner 3800
These guys have the service manual for (sorry couldn't find a free one) $7.99; http://www.tradebit.com/filedetail.php/735166 In this it details how to get into the service mode, when you should get a list of other error codes. The most likely is an E 411, which usually indicates the problem is with the document feeder tray/it's sensors, but see what you get. Please post back with what error details you get, and we can hopefully help if the service manual is not clear on the solution. The E0000000000etc message just means that there is an error considered too difficult for us consumers to deal with. Hopefully not. Hope this helps - waiting for your info :)
Jul 21, 2007 | Canon imageRUNNER 2800 All-In-One Laser...
CANON IR6800
CLEANING WEB MUST BE CHANGE AND RESET
Feb 10, 2014 | Canon imageRUNNER C6800 Copier
Canon ip 1300service rror 5100 -
Canon is a greedy company. It may be selling cheap printers, but the company is so obsessed is exploiting the consumers by selling its ink cartridges that is unusually high. Please boycott Canon printers and let this greedy Japanese company fall into pieces.
Jun 02, 2010 | Canon PIXMA iP1300 Printer
I have a canon copier ir6800 jamming at paper side deck
If the other paper trays work and you use your paper deck more than any other cassette.Your side paper deck tires are worn. You need to replace the 2 pick up tires, the 2 feed tires and the separation roller. Hope that helps.
Apr 21, 2010 | Canon IMAGERUNNER 6570 Copier
E22 error on Pixma MP210
I had this problem as well. After turning on, there'd eventually be a whirring noise followed up by a "CLUNK" noise, and then I'd get the e22 message. Took it down to a local printer place and the guy had a quick look.
- If you open up the printer so that the ink moves to the left, you should see the white plastic cleaning bed all the way to the right. The guy showed me how this thing can be snapped into an up and down position. Mine was stuck in an up position, therefore after the guy pushed it down everything was hunky dory.
Apparently it was cos the printer needs to do a cleaning cycle before it does anything else, so with the cleaning bed in the stuck position it couldn't do it. Hope this helps.
Mar 03, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Can it scan?
OK, you should have canon driver/software cd.On that CD you will find Scan Gear, after installation, open Scan gear and "discover" the ir2020.( copier must be in scan mode) then press select.
Open the word or similar on your pc that is connected with USB to copier.Under tab insert chose the insert from scaner or camera, chose scan gear and custom insert.
Feb 25, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
E15 error codes on a canon dr7580c scanner
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Oct 12, 2007 | Canon DR-9080C Path-Through Scanner
3,893 people viewed this question
k24674
jasbo
jasbo
