Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
Heater leaking water
Why is my Pentair Master Temp. water heater leaking water ? What part do i need to fix it ? Can i get a manual on this heater ?
  • 332 Answers
How old is the unit,, the tank could have gone bad in which case you will need to replace the unit,, thats about the only way out side of a pipe that would leak,
Posted on Jun 30, 2009
  • gary miller
    gary miller Aug 01, 2009
    check the condensate line on the flu pipe, there should be a rubber cap right on top of the unit where the vent hooks to the unit, take this cap off and run a tube to a drain and your problem will be solved
  • 15 Answers
The manual is on Pentair's site. If you are leaking water at the plastic conections you might be able to tighten them down a little. Don't go crazy they are only plastic. There are orings in there and may need to be replaced
Posted on Jun 23, 2009
What caused a loud, low frequency noise upon ignition.
Water in the heating chamber will cause your heater to make these sounds. If your water is cold, it will create condensation inside of the heating chamber. Another way water would get into the heating chamber is if your heat exchangers are leaking. Id check to make sure that heating chamber is not full of water, if theres any real accumulation of water, 2" or more, inside that chamber, the exchanger needs replacing. Otherwise, it sounds like condensation.
Feb 23, 2015 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Clean corroded thermastat
What is a thermostat plunger?
If anything is corroded, Thermister or Temp Sensor, just replace them.
Nov 15, 2014 | Pentair Master Temp 400K BTU Natural Gas...
Why would water come out of the air blower on my pentair master temp 400
take off top[ and see if coming from heat exchange or pressure switch leaking
Jun 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Pentair 400 2 yrs old won't heat spa to 98 degrees F.
This could be a number of things. Most often it will be the internal by-pass. You find the assembly inside the water header, it controls water flow through the heater. When it goes bad it can open at a low temp and keep the water from going through the heater.
Also you will want to check the temp probe on the side of the header. If this is bad it will usually show up on the temp display though.
Nov 18, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Brand spankin' new Master temp 400 NG,won't heat past 77° spa is set at 101°,pool at 88°, does heater pool/spa temps have to be manually set to max(104 i assume) for intellie touch to...
if the intellitouch is properly wired to the heater, it should all be automatic and you should be able to control it all from the remote.
there should be three wires connected to the circuit board behind the manual control on the heater (labeled "POOL", "SPA", "Common"). Those are the wires that the intellitouch uses to communicate with the heater.
You can download manuals from the Pentair website.
www.pentairpool.com
Aug 24, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Pump problems?
Their can be a number of things.. Is the pump priming. Hopefully it did prime. what usually happens after running for awhile, with no cool water coming in. The water inside the pump basket starts to heat up, then the tubing turns to brownish on the input side of pump and exhaust side. (you could have air leaking in throught the input side, which could result in the pump never priming) Or if it is priming and no pressure (can mean your empellar is clogged up)
Mar 07, 2009 | Pentair Mastertemp Heater
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
317 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
