Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Pansonic th-42pz80u hdtv
The hdtv have been ressetting it picture mode to much. IT seems like every 10-15 minutes it says NOW IN PICTURE REFRESH MODE. GOING TO RESSET. DOES THIS SET SUPPOSE TO DO THAT
I had the same problem.  The TV is in store mode.  Unplug it for a few minutes, then plug it back in and select Home mode.
Posted on Jan 05, 2009
My screen is cut off at both ends picture is stretched out
You could be in overscan mode. There might be a video button on the remote that allows switching between the various video output mode.
Oct 28, 2014 | Samsung Un55d6000 55 Inch 1080p Led Hdtv
Toshiba 32A42/32A42A. Just moved tv to bedroom, worked great for 2 days, now the picture has vertical lines. Turned it off for 15 minutes, picture came on, 10 minutes later lines appear again. Anyway to...
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Mar 09, 2014 | Toshiba 32A42 32" TV
Panasonic Viera keeps going into picture refresh mode. How can I stop this?
The tv is on "store" rather than "home" setting. If the message "going to refresh mode" keeps appearing every 5-10 minutes, do the following:
-Unplug TV from wall and leave it for about a minute.
-Plug TV back in and follow "initial setup instructions" (can be found on page 14 of manual).
You will be given the choice of "home" or "store" settings. Change it from "store" to "home".
-Done.
Aug 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
What setting do i need to have my tv on for a game system? Panasonic viera plasma tv. I believe it is a 40"
There is no specific setting that is "required" to be on for a game system, there is a built in mode label game mode, Press the aspect button on the remote, this mode make the picture a bit darker, which will keep any type of static logo from retaining on the screen, if image retention occurs, the logo will fade over time, would have to be stationary on the screen for a few weeks to become permanent.
Jul 18, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Service menu codes
Panasonic TH-42PZ80U Enter Service Mode InstructionsWith TV on, press and hold the volume down button on the front of the TV, and press info three times on the remote. Select Category Instructions1 and 2 Change Data Instructionsvolume up and down Exit Service Mode Instructionspower down Menu Categorywb adj Menu Itemsrgb cut rgb drive all cut all drive -->do not use these unless you need to match ywo displays side by side.
Apr 16, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Replace screen
This is a plasma panel and the part number is: MD65F10A1J and the cost is $3387.95 with a refund of $200 when the bad panel is sent back.
Dan
Mar 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma tv
complete guide here...http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TH-42PZ80U
Mar 03, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
No picture in HDMI
After reading tips on this site I did a manual reboot of my cable box. Sure enough, that had been the problem. I'm going to keep a watch on it from now on; if it happens again, I'll call for a new DVR/cable box. Thanks for all the info on this site!
Jan 14, 2009 | Panasonic TH-46PZ80 46 in. HDTV-Ready...
Keeps going to refresh mode
This is the Panasonic Customer Service Answer:
you need to reset the unit to get it out of store mode sir
make sure the unit is on and we are not in any menu screens
press and hold the volume down button on the front panel
and ok on the remote at the same time until the words self check appears on the front of the screen
once self check is displayed unplug the unit from the wall for one minute
after one minute plug the unit back in and it will go back through first time setup
make sure you pick the home mode
Apr 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
