Panasonic TH-42PX600U plasma TV. No power at all. Where is the fuse (if any)?
  • mmalignaggi Jan 25, 2009
    i hope thats whats wrong with mine.. it just shut off after watching it.. its about 2 years old and i found 2 blown fuses... but don't know where to get the t8ah 250volt.
  • mrsirimage Jan 26, 2009
    I search for a while and finally found the fuses at Allied Electronics, 7151 Jack Newell Blvd. S., Fort Worth, TX 76118. I went to www.alliedelectonics.com and then got an 800 number to call.The fuses are quite costly, around $8 each. After I put in the fuses I did need to have something else repaired on the set. Upon putting in the fuses, the power indicator blinked off and on but the set remained off. Apparently the rate of the blink is a code that an authorised shop can diagnose from and make further repairs.
    Hopefully your fuses are the only problem.
I'm having the exact same problem. My Panasonic 42 inch TH-42PX60U just turned off while I was watching TV. I removed the fuses (both were blown) and replaced them and am now getting the red light that blinks ten times.
What should I do now???
Thanks!
Abbie
abbie.bejrowski@gmail.com
Posted on Feb 08, 2010
    Problem Solver:
  • 6 Answers
Http://www.newark.com/littelfuse/0215008-mxp/cartridge-fuse/dp/42K9308
Fuse is a "Littelfuse 0215008.MXP"
8A 250V Slow-blow ceramic
Posted on Sep 29, 2009
    Problem Solver:
  • 3 Answers
This is Nebster again. If you have a schematic with your manual, it should show a board that connects to the power inlet(power cord from the wall). This board has two fuses. Usually one fuse blows and you get the red blinking lights. The problem is normally not the fuse, it is there to protect the rest of the board. There is a component on the board that has failed. You would have to replace this Board! If your schematic has the board number on it, I could better Identify it for you. If not, Remove the back panel from your tv and it would be the light tan colored board in the mid-upper right of the tv as you face it from the rear. I hope this helps. If not and you wish to talk directly to me, send me a way to speak directly to you.
My pleasure to help,
Nebster
Posted on Jan 31, 2009
Where did you get the fuses.. i have 2 blown fuses on the same unit and it doesn't turn on.. but having trouble finding the fuses...
Posted on Jan 25, 2009
  • 1 more comment
  • mmalignaggi Jan 31, 2009
    Nebster.
    Both fuses blew. I put 2 new fuses in. And know i get the linking 10 lights.   After reading your post you say to replace the board that has the 2 fuses.  i will have to look at my service repair manual, but on the service repair manual it says to replace the pa board and h board. if its blinking 10 times.   I don't think those are the board with the two fuses.   I just want to try to get the correct board the first time instead of spending a ton of money on boards.   Did you have the same problem with yours, and it was the 2 fuse board that needed to be fixed?   They don't keep blowing the fuses, just did it once, and when i put the 2 new fuses in it blinks 10 times.   If you can call me directly at 860*982*7284 that would be GREAT!  Thanks... Mike.
  • mmalignaggi Feb 20, 2009
    Hey nebster,
    Can you give me a call 860-982-7284 about the 10 blinking lights and pa board..
    thanks.
    MIke M.
  • mmalignaggi Feb 24, 2009
    Nebster,
    I checked the resistance on the two white resisters on the power supply board. one has no resistance. Ill let everyone know what my outcome is when i get the power supply board.
    Thanks
Removed the back of the set (about 30 screws) and located fuses right near the power cord input. There are two, both are T8AH 250 volt. One was bad one was good. Replaced and all is well.
Posted on Nov 12, 2008
24inch Bush smart TV/DVD not working.
Could be an open internal fuse or power supply failure
Jan 09, 2017 | Bush Televison & Video
Vertical lines on my plasma tv
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 08, 2017 | Samsung Televison & Video
How do i fix black spots on my LG plasma tv. model 50pj350ub
Jan 08, 2017 | LG 50PJ350 50 HDTVReady Plasma TV
Samsung plasma TV model #pn42b400p3dxza problem with no image. The TV has sound but no image. I've tried using other components on the TV like RCA jacks with a separate TV digital tuner. Thank you
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Check whether Va & Vs voltage come to the display panel, from the main power supply regulator board. If not, the SMPS board [power supply regulator board] is faulty.
I have pioneer plasma tv about 6 years old. I turned the power on, sound but no picture. Do you think it is worth fixing?
no
plasma tv units consume considerable power and the latest led units don't so for the extra cost of a new unit , there will be a power saving over the years
Jan 08, 2017 | Pioneer Televison & Video
Just bought a new smart tv and my panasonic recorder keeps saying not connected - why
Usually this message is because there is no direct connection between the recorder and the TV!
where do you see the message, if on the recorder then check cable connections! if on TV then turn on the recorder!
Jan 07, 2017 | Panasonic Televison & Video
50" LG Plasma Screen TV does not have any sound or activity on the screen.
input correct ? eg:HDMI 1 USE MANUAL TO GET INTO SETUP MODE.go through all settings.check the contrast and brightness buttons n the TV if any on back or top.
Apr 15, 2013 | Televison & Video
Televison & Video Logo
1,153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
