Back to:
Tags:
GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Problem with fresh food side of my refrigerator... (by 2 users)
posted by engwah on Oct 29, 2006
Dear sir,
I have overseas (240 volt)GE Profile Side by Side Model TFG28PFD Refrigerator Freezer. The problem started with the Fresh food side not cooling. The repair man determined that the problem was with the cooling fan located in the freezer section of the unit. The fan was changed and the system seemed to function OK, however, the next morning The upper light bulb in the fresh food section was malfunctioning, It had a dull orange glow and after a short time ceased to function entirely(the bulb is OK). It was also evident that the fresh food section was again not operating. The repair man is unable at this time to determine cause although he suspects it may be a circuit board problem. I would be happy to hear your opinion about this probblem.
Regards John Charters.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by annaleigh, posted on Nov 05, 2007
We have a Samsung side by side 25 cu ft refrigerator. The freezer side is set as low as it can go and it still freezes ice cream hard as a rock. However, the food side is set as high as it can be set and food still ruins too soon and my thermamature shows barely 40 degrees???
Best Solution
posted on Nov 10, 2006
Thanks for Trying (70)
HVACRH20
Rank:Guru Guru
Rating: 85%, 1242 votes
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problem with fresh food side of my refrigerator freezer:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
GE Profile PSW26P Stainless Steel Side by...
There is water to the grey plastic tubing to the...
I have the same problem. Did you get yours solved? did you...
was drying and opened door to remove an item, closed door...
We bought our GE profile sid by side stainless steel...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
