Question about Sony DVD/VCR Progressive Player
Unlock Sony Progressive Scan
My DVD/VHS player shows "locked" on the display and I cannot play either side. Do you know how to unlock?
SOURCE: insignia dvd/vcr combo progressive scan mode
thanks worked great
Posted on Aug 05, 2007
SOURCE: Locked into progressive scan AND Setup is Unavailable
This solution will also work for GoldStar DVR1000! make sure no DVD or tapes are in the player press and hold stop button and it releases you from Progressive scan mode. After searching the web for hours for this model got desperate and was trying fixes for other brands and models, this one worked. Thanks koolanit
Posted on Aug 19, 2007
SOURCE: SD-K530SU - Turning Off Progressive Scan Mode
Sure that's easy, I read this in the manual:
http://tacpservice.toshiba.com/ConsumerProductSupport/Manual/dvd/SDK530.pdf
(Page 18 - Progressive Scan Section)
All you have to do is:
1. Remove the disc in the DVD/VCR.
2. Press and hold the STOP button for 5 seconds before releasing it. (Note that this is the stop button which is physically on the player.)
And that should pull you out of Progressive Scan Mode.
Posted on Nov 06, 2007
SOURCE: SONY BDP-S300 unlock region code
DVD PLAYER SAYS CANNOT PLAY THIS DISC
Posted on Jan 24, 2009
  • 50 Answers
SOURCE: Want to unlock my lgV692WK dvd vhs combo player
1. Turn on dvd without disk
2. Press pause
3. Type 314159 wait for menu to apper
4. Press 0
5. press pause
6. Turn off for 10 sec then back on
7. Regionfree!!
Jay
Posted on May 21, 2009
Unlock Sony BDP-S1200
Have you been playing cd etc from different countries. The cd units in this country will lock you out after about three tries, that is the law.
Dec 19, 2014 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
Sony blu-ray player BDP-S280 unlock
Turn on the Sony Bluray disc player - BDP-S280. Press and hold the play button for 10 seconds. It should display unlock on the front panel display. You can lock by pressing and holding the play button for 10 seconds again.
Oct 20, 2012 | Sony DVP-NS330 DVD Player
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Netflix dvd not playable on SamsungDVD/VHS
Buy a cheap DVD player under $50 they play anthing.I have a $600 Toshiba Tivo DVR that won't play some DVD s.My $32 RCA plays anything.Good Luck.
Sep 07, 2009 | Televison & Video
How do you know if you have a Progressive Scan TV? We are having problems playing DVD's from video stores. It will play the previews, but when it gets to play the movie, it doesn't play. I can play them...
Well, a progressive scan TV displays in the same resolution as a normal interlace TV. It's very hard to tell the difference in all respect.
Progressive rewrites every single line/pixel on the screen. Interlaced simply skips a line and rewrites half of the lines every frame. So, progressive can show higher quality, but interlaced was more predominant as it was easier to create for TV makers in the earlier days.
Most of today's better televisions are strictly progressive and you won't have any problems.
I'd try a different DVD player with the selected titles and see if the problem persists. It could be the TV or the or the player itself. If the titles work in another DVD player. Try a newer television and see if it works there.
Hope these ideas help.
Sep 21, 2008 | Televison & Video
Sanyo dvd/vcr dvw 7000
I have a Sanyo Dvd/vhs player and I recentlty went to dish network instead of cable and I do not know how to get the player to work now so I can watch movies that I have rented. Can you tell me how to use the remote to watch movies.
Apr 08, 2008 | Sanyo DVW-7000 DVD Player/VCR
DVD Player Stuck In Progressive Scan Mode
A simple solution that works with electronic items many times, so give it a try. Turn Off your player, un-plug the electrical supply, wait about 2 minutes then re-connect the electricity and turn on the player. Many times this will force the machine to reset itself. This technique can be used for ALL electroinc devices.
Jan 16, 2008 | Zenith XBV243 DVD Player/VCR
Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
Jan 07, 2008 | Televison & Video
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Televison & Video Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
