Question about Philips HD-7810 Espresso Machine
We have a Philips Senseo coffer machine, we are having trouble getting the Douwe Egberts cappuccino coffer, can we use any other brand of pod and cappuccino coffee or does it have to be Douwe Egberts?.
Senseo now makes pods in many coffee flavors and coffee varities
can be bought via internet
Posted on Nov 16, 2009
Why wont lid on my phillips senseo hd7863 close when the pod is in the holder ?
Maybe you inserted the pod with the wrong side up or you used a 2-cup pod in a single cup holder. If the clamping spring isn't working (the lid feels loose when you try to close it), that spring (that is nothing more than a straight piece of metal wire) needs to be replaced.
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
Senseo 7860 leaks
maybe you can see more at the Philips website
7860 leaks... where????? SENSEO Coffee pod system HD7850 60 Latte Select
Jan 19, 2014 | Philips Senseo HD-7810 Coffee Maker
The machine starts then suddenly gives a loud pop then the seal is broken and coffee LEAKS out
That's one for the repair shop, really. The seal is usually bent inwards so it can withstand the pressure of the hot water, but once it's able to flex out it needs to be replaced.
Oct 19, 2010 | Philips Senseo HD-7810 Coffee Maker
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
My senseo machine doesn't seem to produce the crema layers even though i've followed all the instruction
You may find that the plastic disc on the bottom of the pod holder is not sealing (there is an O ring) ,if the amount of coffee dispensed is more than usual that will be the problem,just buy a new pod holder.
Oct 06, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
My philips senseo new generation won't open I suspect a vacuum-problem but don't know how to solve this can you advise me?
Eureka! I have solved this problem.
Disconnect your Senseo from the power. Take it to the sink. Hold it upside down and put hot water in the coffee outled. In less than 30 seconds the senseo will open.
The problem with Senseo is that - especially with coffee holders for 2 cups and chocolate - after making the coffee, the pod holder and the pod cool down. This creates an underpressure, that prevents you opening the Senseo. Hot water will increase the pressure and then you can open the senseo very soon.
This solution was found in despair after struggling with all the complex tool involving (knives, pumps, etc.)
Let me know if it works for you
Hans Beers (hansbeers@zonnet.nl).
Mar 26, 2009 | Philips Coffee Makers & Espresso Machines
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips HD-7810 Espresso Machine Logo
126 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
