Question about Sharp Televison & Video
Iam looking for the remote control code for a sharp LC32BT8EA to use my sky remote.
  • 13 Answers
SOURCE: Remote control code
try these codes
0063, 0163, 0266, 0355, 0455, 0555
good luck!
Posted on Feb 09, 2008
aprmaejun
  • 97 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: I HAVE A NEW SHARP
I can find a good code either but to turn on and off tv and adjust volume use code 1221
Posted on Aug 16, 2008
  • 905 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
SOURCE: SKY remote control programming
I used 0081 for the KENMARK LVD160 and it worked straightaway. This was for a REV 6 - SKY remote.
Posted on Mar 14, 2009
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I have a lg hdtv..and I have just got sky hd..I just want the remote contral code for the sky..then Iam only using 1 remote????can you help me please.
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
http://www.satcure.com/tech/digicode.htm
May 29, 2010 | Televison & Video
I need sky remote code for sharp tv model no lc-32sh7e
Hi there. I hope you will see this reply. I bought one of these TV's yesterday and I've got the code from my dad's website www.satcure.net
If your remote is Version 6 then you will be able to follow the help on the sky box under
Interactive
Customer service
Program Remote
Then follow the steps using code 1221
If you have a Revolution 8 remote then you will have an easier job but with a 3 digit code.
3 digit code is 253
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Hope this helps/works!
Apr 21, 2010 | Sharp Televison & Video
Im trying to get my sky controls volume to work on my sharp tv but need a code
On the Sky remote Press the Following.
TV,
RED + SELECT (blinks twice)
TV,
0093
try the VOLUME if this does not work. Press TV then VOLUME again repeat until Volume works.
Once the volume works press SELECT on the remote to store.
Hope this helps
Little Dish Fitter
Aug 26, 2009 | Sharp Televison & Video
Pin code for wharfedale tv
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Oct 18, 2008 | Televison & Video
How do I get the volume to work on my sky remote control?
SHARP TV
follow the steps below
TV
RED + SELECT
TV
0093 (sharp code)
press the power button if this turns your TV off then press SELECT to save. If not press TV then POWER. repeat this step until it does turn your tv off remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Sep 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I HAVE A NEW SHARP LC-46X20E and need the SKY remote control Code to program in. Thanks
I have used 1221 for my LC-32X20E and all functions of remote control works fine
Aug 16, 2008 | Sharp Televison & Video
SKY REMOTE CONTROL CODE FOR SHARP LC-37X20E TELIVISION
You need code 1221 for this tv. I have the same tv, and using a rev.6 Sky+ remote, everything seems to work fine with that code.
As Sky seem completely unaware of this television, and possibly countless others, people should use the following site for a more complete remote control list than Sky themselves have:
Jul 18, 2008 | Sharp Televison & Video
Televison & Video Logo
20 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
