Intel Desktop Board D865GBF/D865PERC 865G wont boot
I have recently purchased Intel Desktop Board D865GBF/D865PERC 865G.
i believe i have put the front panel pins in properly but it wil not starts. the fan starts for a breif second then stops. im running it on a 235w psu could this be the problem? if not i have no idea what else i can try any advice would be greatly appreciated.
  • babezone Nov 14, 2008
    hi thanks for your help it was the psu as i first thought. i didnt have a 12v conecter i now do and its working cheers
  • Anonymous Dec 21, 2008
    I have intel D865GBF mothe board and using from last 3 years, my son was working at paintbrush software, it switch off, now as i start the processor fan starts for few seconds and then stops. i have check RAM, also remove pci and HD drive but the problem is still existing
  • 207 Answers
First double check your front panel Connector it is laid out as follows
The power switch should attach to pins 6 & 8. The Pins for the reset switch should attach to pins 7 & 9 if its a two pin connector if it is a 3 pin Connector add in pin 5
The power LED connects to pins 2 & 4 The HDD activity LED attaches to pins 1 & 3.
If either or both of these LED's don't light up when the PC is running then reverse the pins for the respective LED(s)
Once the connections are confirmed
Check that the CPU is properly seated, the RAM and Video card connectors have lock down latches. Make sure they swing up and fully seat into the notches on the Ram modules and Video card
Make sure that both power connectors are attached there is a 20 pin ATX connector and a 12V connector (a 4 pin square connector) next to the CPU they should seat until the plastic clip clicks into place.
If the Video card you have chosen has a seperate power connection make sure that has been attached.
You should now be ready to give it a try again. If when you try to turn it on again you see a light on your Motherboard you know the board is OK. If not you may have a damaged Motherboard (Which you should get replaced under warranty)
If the light comes on but your PC tries to come up and it shuts down again immediately, you likely have either a damaged CPU or bad Ram modules. Which you should also replace under warranty.
If you have any further questions please post a comment here and I will try to help you further
Posted on Nov 11, 2008
No power but power pack is ok what is the problem
Posted on Feb 22, 2010
What year is this board
It was made in the year of our Lord - 2003
It was a cold dreary day in March, and no big fanfare of computer geeks wanted to see the board. Quick meeting, and out the door.
AGP 8X technology.
No SATA RAID features
No voltage adjustments in BIOS Setup.
Aug 17, 2012 | Intel Desktop Board D865GBF (MBIND865GBF)...
Intel D865GBF 865G Motherboard Review
Keep in mind that the 865G board on the bench today represents one chipset from a family of three other "mainstream" platforms. The "G" denotes that the silicon includes an integrated graphics controller. Its brother, 865P, is the entry-level solution with 400/533MHz front side bus support and DDR266/333 memory support. Finally, the 865PE features a 533/800MHz FSB and the same dual-channel DDR400 memory bus as the 865G we
Sep 20, 2011 | Intel D865GBF Motherboard
Intel D865GBF/D865PERC does this mother board support 450W SMPS or higher. If heigher how much Watt does the mother board support
You can install a 450w or higher wattage switch mode power supply.
The total wattage of the power supply you require depends upon the power consumption of all the devices that are installed on your computer and any additional devices you may wish to install in the future.
I suggest you need not exceed the total power requirements by more than 10%.
It is like putting a jet engine in your car when it does not need this much power and it would cost more money.
May 08, 2011 | Intel D865GBF Motherboard
How to dowanload sound max driver of intel desktop board d865gbf / d865perc
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows
operating system. Please click on this link andselect your model motherboard : -
Feb 24, 2011 | Intel Desktop Board D865GBF (MBIND865GBF)...
I am facing problem regarding BIOS, Therefore i want to update BIOS, My bord is Intel Desktop Board D865GBF/D865PERC. Please advice me to get free download
Go to the Intel site and enter the required details
Jun 16, 2010 | Intel D865GBF Motherboard
Sir, i have lost my motherboard cd sir ,my
Go to intel side or chipset web add . see your motherboard . nere the processor they will mension the motherboard no ( i.e d845 / d915 )
Jun 11, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
I need audio driver for Desktop
Here you go. follow this link, choose your OS from the drop down list, then choose your drivers.
You'll have to agree to the terms and conditions before the download.
good luck
May 19, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
**System randomly hangs**
Electrolytic Capacitor Failure on some Intel mobo. Products Affected:
Intelreg.gif Desktop Boards D865GBF, D875BZL, D865GLC, D845EPI, D865PERC, D865GRH, D865PERL, D845GVSR, D865PESO, D845GLVA, D865GWV, and Intelreg.gif Entry Server Board S875WP1-E.
Should replace the capacitors shown in the photo attached. 73d0b16c-0d36-4176-be42-6dd73b32fb65.jpg
Oct 24, 2008 | Intel D865GBF Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Computers & Internet Logo
2,768 people viewed this question
David Payne
David Payne
