Question about Neff 24 in. S5456 Built-in Dishwasher
Neff built in dishwasher
We have a 5 year old neff, all the functions appear to work but it simply dosnt clean, when you open it up mid rinse cycle I dont think the top rotar spins allbeit water does come out of it. Ive done the obvious things and taken them off and cleaned them and they appear to be free. could it be low water pressure?
Chris
    President:
  • 1,462 Answers
These arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Posted on Nov 10, 2008
SOURCE:
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Jan 01, 2014 | Neff Dishwashers
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Jun 01, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher stuck in cycle
Hi
I have a similar problem, did you find the cause of the problem?
Geoff
Jan 13, 2010 | Dishwashers
Maytag Dishwasher Will Not Rinse
You are probably not getting enough water into the machine. Replace water inlet valve (solenoid valve) and this should solve the problem.
Nov 13, 2008 | Maytag MDB7100AWB Dishwasher
Dishwasher not washing very well
usual reason is that the arms are not rotating freely - they only turn by water jetting out of angled jets. blockages are not always obvious as blockage material tends to go out of sight when water pressure off. favourite culprits are rice and sweet corn
Mar 09, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Inside of dishwasher not clean after running.
its a lime build up from the quality of your water.goto home depot/lowes or a supermarket and buy clr (calcium lime rust) remover.pour a cup in the dishwasher and run a full cycle.this should do the trick.
Jan 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Neff Dishwasher
It sound like a detergent cup issue (not opened in time). The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Let me know with your results. Good luck!
Sep 05, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
345 people viewed this question
Top Neff Dishwashers Experts
Ekse
Marvin
Marvin
vince
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
