Question about Curtis-Mathis CM19011 TV
Converter box attach to a 1985 curtis matis tv with built in rabbit ears on top of tv
Can I get step by step instructions so i can attach a converter box to my 1985 curtis mathis tv that has rabbit ears built in on top of tv?
What is the brand of curtis mathis tronics..?
Posted on Jun 20, 2009
How to hook up T V ears on 32 " element tv ( elucfw329 )
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Jan 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
Want to set this up without cable. Someone told me to go to "air" mode and add rabbit ears and this will work. I cannot find an air mode on this tv. How do you set this one up with rabbit...
You will once again, purchase a converter box to receive an over the air channel. I don't think you will have to really worry about using an over the air mode on the TV. It may be in the menu, but will work otherwise after being placed on channel 3 to receive through the converter box. The rabbit ears will be connected to the converter box itself.
Feb 13, 2011 | Televison & Video
Have a Magnavox TV , Rabbit ears
You may have to try a different universal remote control.
Jan 20, 2018 | RCA 3-Device Universal Remote
Can I use a regular antenna
Yes. You can use a regular antenna for any flat panel HD TV. You're only limitation the type of antenna and whether or not your flat panel TV has a built in digital tuner. If it does, you'll be able to scan for digital channels without any additional components, including the High Def ones,  though you may not get every channel available with a set of rabbit ears. A roof top antenna will give you a stronger signal and more channels. If your TV does NOT have a built in digital tuner, you'll have to purchase a digital converter box and attach your antenna to it to receive the digital and HD channels. Good luck.
Jun 30, 2009 | Panasonic Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
If you have Cable, or sattelite tv, then no. Or if you if the rabbit ears and the tv has a digital tuner no. but rabbit ears and an anolg tner then yes.
Oct 26, 2008 | RCA F27442 27" TV
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
Magnavox TB 100 MW9 STB Converter Boxes I'm trying to solve the antenna/rabbit ear connection from this converter box to the t.v. I only get a pic when the rabbit ears are connected to the back of the...
Analog signals have nothing to do with your problem. Make sure that the TV is set channel is set to 3 or 4 (cf read of Converter box for channel switch). The TV received signal from Converter box on Channel 3 (or AV Cables if you have them)
Jun 11, 2008 | Televison & Video
Hook up old tv antenna to converter box
how do you hook up a tv with just screws to a converter?
May 27, 2008 | Televison & Video
Need converter box
Not if you have cable TV, satellite TV, or FIOS. If so, a converter won't do anything for you. Not needed.
If, however, you only use a regular TV antenna or rabbit ears, you will need a converter box as this model TV only has an NTSC analog tuner built in.
Jan 04, 2008 | Sanyo DS24425 24" TV
Curtis-Mathis CM19011 TV Logo
298 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
