Question about Frigidaire CWS3600AS Top Load Washer
Fridgidaire Washer burning belt!! Help
Ok, washer belt was 8 years old stuck and burned.. I go get a new one washes 4 or 5 days ok.. burns the belt again. Everything seems to turn ok.. could the ilder pulley spring be weak?? Or maybe its trying to spin before all the water is out? Im not sure what to do but a washer isnt such a high tech thing... Ideas? Thanks;....!!!
Washer is a 1995 mfg date dont have model handy... not much use was stored from 95-99
  • 903 Answers
Http://www.applianceaid.com/frigwestwasher.html#burnt-belt
look on this site for more aid, it may not be your exact model but has advise on burning belts
Posted on Nov 18, 2008
My washer wont spin and it smells like it is burning it is only 3 yrs old
The burning you smell is probably the belt slipping. There is a belt which is attached to pulleys. The belt engages to spin the basin in the washer. When this belt slips the burning smell happens because the pulleys are spinning and the belt isn't. You will probably need to adjust the tension on the pulleys or get a new belt. This can happen from constantly overloading the washer or trying to get the washer to wash and extra large load while the water level is set at a smaller load.
Aug 07, 2010 | Maytag Washing Machines
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
My washingmachine stopped working and gave off burning smell. How can I determine if its the motor thats burned out or something else?
Had one similar to this about three years ago. That burning smell would be the belt that runs the washer. Relatively easy to repair. You'll need make and model number to get the right replacement belt. Once you have it, get up under it, remove the old belt and put the new one on the same way. The belt will go around the pulley on the bottom of the washer drum, the motor and the tensioner. This should solve your problem. If you need more help, please let me know.
Oct 27, 2009 | Frigidaire FEX831CS Top Load Stacked...
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Sep 27, 2007 | Washing Machines
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire CWS3600AS Top Load Washer Logo
131 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
