Back to:
Tags:
Proficient S12 Subwoofer
Proficient Subwoofer S12 - No Power (by 2 users)
posted by bengalbreaux on Oct 29, 2006
I notice while watching movies there was no bass. Did the speaker check and nothing. I did unplug the sub and plug into another outlet, just to make sure. Bottom line - No power. What is the checklist I can do to correct this problem or checklist to identify the problem? Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Fufanuer, posted on Jun 17, 2008
I have a 12 inch Proficient Subwoofer and it blew a fuse. I tried replacing the fuse and before I even turned it on it blew the fuse. I tried two new fuses and each one blew in standby mode. I have it on the right voltage 115. Is there something inside the sub with wiring that can be fixed?
Best Solution
posted on May 24, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Check the fuse which tends to blow frequently.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Proficient Subwoofer S12 - No Power:
I don't want to Accept this solution
Solution #2
posted on Dec 09, 2007
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
Throw this sub out the door! I have one two years now and had to sink $250.00 in to it for repair just after the 1 yr. warranty ran out.And as I am writing this it is not working.My solution: Get a Velodyne dls5000r,I am : - )
Thank You!
Can you Help with these Home Theater Speakers and Subwoofers problems?
I ordered the caps that you specified in your fix. Do you...
hi i have a telefunken surround sound that i cannot get to...
I can't play mp3 and dvds that i copied from my pc. Seems...
Hello, Problem with Panasonic home theatre model SA-HT540...
One of the output transistors shorted, a 2SC3281. There...
Loading problems.
Repair Service
Find Home Theater Spe. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
