Question about Sony Cyber-Shot DSC-P200 Digital Camera
Lens not opening when turning on....
When I turn my camera on, it shoots the lens out as it always has but the cover over the lenses remains either partially closed or completely closed. Why is this happening and what can I do to remedy it?
  • 188 Answers
There is a friction in the cover movement, due to some sand or foregion partical. blowing a heavy puff of air, by blower may solve the problem.
Posted on Oct 29, 2006
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
How to open lens cover?
If it's professional camera... squeeze the tabs at the edge of the lens cap toward the middle and it will come off easily. If it's point-and-shoot camera then turn the power on and it should open automatically. Sony NEX should be a quarter turn or so and it will come right off. Otherwise, give a model and you answer will be more specific. Good luck!
Aug 15, 2011 | Sony Cameras
Lens keep extended in an out
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Permanent error 06. 17-85 lens damaged when an
It most likely was a short in the repaired lens that caused the sensor to go bad over time.
I have been shooting with Canon cameras and lenses for many years and I do not always turn off power before switching lenses. It is not a big deal.
Jun 06, 2009 | Canon EOS 40D Digital Camera
Lense will not extend, or if it does it retracts after a short while. Batteries appear to be OK
After talking, without any success, to your expert I tried experimenting. It seemed like the sliding lens cover was the main reason for it to behave as it did. It turned out that the lens cover had a worn track and did not always operate the lens motor switch to open it, or pressure on the cover caused the lens to retract. All it needs is a new sliding cover.
Jul 18, 2008 | Olympus Cameras
Kodak DX7440 Lens Cover does not open or close properly
It is a common, but in most cases intermittent problem with many cameras regardless of brand/model. I also own Kodak DX7440 since late 2004, and I had this problem twice, in 2007 and 2008. First suggestion: fully recharge the battery, it helped me the first time. Second: play with the lens cover, that is try to open/close it with the camera on/off. With me, in 5 min of these attempts, it suddenly fixed itself and stays this way for one month now. Another suggestion: dont use a toothpick, since it can scratch the lens. Use a q-tip, and to avoid cotton threads sticking to lens, wet the q-tip and let it dry.
Jan 03, 2008 | Kodak EasyShare DX7440 Digital Camera
Canon digital rebel xt :error 1 message
I agree with dovi. I actually emailed canon and here is what they said and how to do it; Thank you for your inquiry regarding your digital SLRs. We value you asa Canon customer and appreciate the opportunity to assist you, and I'm sorry to hear that you're running into the "error 1" message. From what you mentioned, it sounds like the lens might be having problems communicating with your cameras. One thing you could try is toclean the contact points on your lens and your camera. If you have not done this yet you can do so by turning the camera off, removing the lens, then brushing those copper points on both the lens and the camera body with something like a clean eraser. Should problems continue, I would suggest that you go to a local camera shop and try a different lens. That way you can determine whether the problem is due to the lens or to your cameras. I hope this is helpful Jason
Sep 04, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Camera lens cover
Broken or damage a small switch under lense cover create this type problem
Apr 30, 2007 | Sony Ericsson K750
Cover open, camera does not turn on.
Completely open lens cover by sliding the lens cover all the way to the right until you hear two clicks. The first click will put the camera into playback mode. The second click will put the camera into shooting mode.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Sony Cyber-Shot DSC-P200 Digital Camera Logo
88 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
