Question about Canon ZR45MC Mini DV Digital Camcorder
Warning signs and definition
There is a warning sign appeared on the screen but I dont know what this sign means. Then when I record the white blank appeared on the monitor
    Problem Solver:
  • 10 Answers
Try to run cleaning tape.
Posted on Nov 14, 2008
What is the sign mean with a sun and a thurmanitor thing mean
It could be a transmission temperature warning indicator. Have a look below for definitions to many of these cryptic looking symbols:
Picture Symbols
May 28, 2014 | 2004 Nissan Armada
How do u know when to replace the bulb ? Does ig just go off instantly or is there warning signs ? I have white specks appearing on my images thanx val x
It is not correlated with the lamp
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip. I supply it ,USD200
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 04, 2014 | Acer X1130P 3D Ready DLP Projector...
Warning light just appeared. Circle with a triange inside. What does this mean?
We try to apply all option as named but not helpful.
Another way was to disconnect the car memory disc and connect it again then car start as normal. Problem was the loose memory during the time i drive on across on rainfall flood.
Secondly engine check and abs sign remain appear on the screen these still existing to date although a car is running.
May 13, 2013 | 2001 Volkswagen Golf 2.0
Yellow Camera in LCD Screen with a ! sign. What does this mean?
The camera is warning you that the shutter speed may be too slow for you to handhold the camera steady enough to prevent camera motion from blurring your photo.
For full details refer to the "Warning Messages and Displays" section of the manual (page 113 in my copy). If you need a manual you may download a copy here.
Apr 29, 2012 | FujiFilm FinePix S2940 14MP Digital Camera...
WHAT DOES THE TRIANGLE WITH THE ! IN IT MEAN?
It is a Warning sign.
Warning sign - a sign giving warning of a hazard or danger (eg danger: electricity)
Jan 17, 2012 | HP LaserJet P2015 Printer
Warning sign of "ADS" appeared
you mean abs not ads stands for anti brakeing system have your checked its throwing a code have fixed then light will go off its telling you somethings wrong somewhere in your brakes
Feb 12, 2011 | 2000 Pontiac Montana
I have a warning signal on my dash board but I don't know what it means. It looks like an amber exclamation mark inside parentheses with a flat bottom.
I think its your handbrake warning sign...try to check your handbrake warning sign switch..may be the switch is shorted.
Jul 06, 2009 | 2005 Toyota Corolla
SEAT TOLEDO WARNING LIGHTS
Could be the motor-management-warning light, but I guess it's the break-warning light. There might be too little breaking-fluid left in the lines ... A boardcomputer-readout should clarify this.
Otherwise, try parking on an ascending road with the nose pointing up, hit the hand-break and wait like 2 minutes; the light should come on. You might wanna retry it with the car's nose pointing downwards as well ... If so, definitely the breaking-fluid, otherwise probably not ;)
In any case - flashing warning light are never ok, so when you see it again and you're sure it's not just the ABS/ESP warning light, go and have your boardcomputer read-out, since it should contain useful errorcodes ..
Feb 07, 2009 | Volkswagen Passat Cars & Trucks
A warning light appear with my hibrid prius
I have same engine problem. Triangle signal pop up after I try to start my Prius with a still wet air filter to the car . The engine just run for less than 30 sec. and stopped with the triangle signe pop up. I think this sign will pop up whenever the engine detect certain major function failure. For my case, it was due to retricted air supply to the engine. I have tried Lovebytes suggestion and the triangle sign disappeared with a dry clean filter. My Prius is running good now. This warnig sign may have other implications. Once you try this method and sign still come on. You need to have your car check by garage.
Bellow attach is the answer from Lovebites
cc1dd82.jpg Lovebytes
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I had the same problem. I unplugged the relays from the fuse/relay box under the bonnet. (Top left side) and replaced them. The problem disappeared. (2001 Prius 109,000 miles)
Jan 05, 2009 | 2001 Toyota Prius
Canon ZR45MC Mini DV Digital Camcorder Logo
117 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
