Question about HP OmniBook 500 Notebook
HP omnibus 500 memory upgrade
Hi all
Have an HP omnibus 500 running a bit slow these days (like me) thinking about trying for an upgrade.
Q: A where to find and how to remove the existing module.
B found this upgrade on the net £28 will this do the job. (specs below)
C be greatfull for any tips do's & dont's
Many thanks
Module Size: 256MB
  • Package: 144-pin SODIMM
  • Feature: SDRAM, PC133
  • Specs: SDRAM, PC133 • CL=2 • Non-parity • 133MHz • 3.3V • 32Meg x 64 •
  • Posted by on
    Amount of ram Hp designjet 500 plus 24 inch and amount of ram support for Hp designjet 500 plus 24 inch.
    According to the service manuals there is no memory upgrade for the 500 and standard memory is 16mb.. The 800 and 510 only have upgrade capability.
    Apr 05, 2015 | HP Office Equipment & Supplies
    My hp g62 is very slow
    The issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources etc. Learn how to quickly fix the issue from: http://www.speeduphp.com/fix-slow-hp.html
    Dec 25, 2010 | HEWLETT-PACKARD HP G62 Notebook
    Hi i have compaq presario c700 its too slow discr
    If you have changed OS, your problem probably is not due to malware or bloat.
    Upgraded to 2gb ram, new hard drive. And still you think it is too slow.
    I think either you are too fussy, and expect too much OR your laptop has major problems at a chipset level.
    Have you tried running some benchmark software to check if it really is running slow???
    I would Do a fresh install of windows, SELL it and change to a different model.
    Try checking a couple of reviews on sites like Custom PC, for a good fast laptop.
    Aug 21, 2010 | Compaq Presario 700 470024-192 Notebook
    The system is slowing down when I use WD 500 GB ...
    Hi mortonwood12. it could be two things. 1.- you have way too much information on that drive and 2.- either the enclosure or the hard drive is going bad. (Sorry to be this harsh). What I recommend is get another hard drive and backup all your data "pronto"!. Then remove the hard drive from the enclosure (it could be a little tricky) and then trying connecting the hard drive internally. If you still have the same problem, then it's the hard drive. Dont use it anymore. I wont get any better. I hope this helps and please dont forget to rate and provide positive feedback for our free support today. Thank you :D
    Apr 29, 2010 | Western Digital My Book Essential 500GB...
    I want upgrade my HP desk top computer memory?
    What is your current memory?
    As it is a 32 bit processor, it will support maximum of 4GB.
    -rate if it helped you.
    Apr 08, 2010 | HP Pavilion a1213w (ED898AA) PC Desktop
    Slow laptop, canot upgrade
    It cannot be upgraded farther by hardware. You should be able to run xp there. Any lower requirement linux distro is also fine if you like.
    Laptops are now-a-days not too costly. May also think about a new one.
    May 21, 2009 | Dell Latitude L400 Notebook
    Ram Upgrade
    Max speed supported for your mobo is: DDR2-533
    You will have to buy (4) 1gb sticks (2gb sticks not supported)
    To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
    Here is the specs :
    ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
    CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
    Chipset: Nvidia GeForce 6150 LE Chipset
    HD Bus:
    Front Side Bus options:
    Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
    Special notes:
    - Motherboard manufacturer's name: ASUS A8M2N-LA
    - HP/Compaq name: Nodus-GL8E
    NOTE: *Actual available memory may be less w/o 64 bit os
    Dec 24, 2008 | Computers & Internet
    Computer running way too slow
    Ram always helps I would also see about getting a video card even a cheap one will help out quite a bit.
    Try this website http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en%3F=en&lc=en&product=436205&cc=us&dest_page=product&docname=c00255724
    is says ddr sdram only 1 gig is allowed though.
    Jun 08, 2008 | HP Compaq Presario SR1265CL-B...
    Choosing/upgrading DDR memory
    hi there,
    i dont see why u should not upgrade to 1gig RAM ... but u should stick to one memory speed ...and Size but if u can try to get the PC2700 - DDR400Mhz memory
    Apr 14, 2008 | Syntax SV266A SKA KT266A Motherboard
    Upgrade laptop
    Hi
    Only you can upgrade laptop ram and hdd. You cannot upgrade your graphic card, try to upgrade your ram it will improve speed....
    Apr 01, 2008 | HP Pavilion dv6000z Notebook
    HP OmniBook 500 Notebook Logo
    73 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
