Question about Whirlpool ED5FTGX Side by Side Refrigerator
Not cooling I power my new fridge and left it to run for 24hrs with no load according to the manual and it's not cooling
  • simpi2002 Nov 10, 2008
    Both sides are warm
  • simpi2002 Nov 11, 2008
    The compressor is very very hot
    Scholar:
  • 66 Answers
I may be able to help. First I need some info from you. 1st- are both sides of frig warm or just one side. If the freezer side is cold but not the fresh food side, it could be an air circulation problem. If niether side is cold, then it could include a compressor problem or a cold control problem ( cold control problems are normaly not the case )
Posted on Nov 10, 2008
  • Charles Caldwell Nov 10, 2008
    If you have the frig pulled out away from the wall, you will need to determine if the compressor is running. By feeling the side or top of the compressor, check to see if it cold or warm or hot.. Hot would be too hot to keep hand on compressor. if it is cold then the compressor is not doing any work. This could be due to a bad compresssor or a start solinoid on the side of the compressor bad. If you are able to check the compressor, please let me know how it feels.
  • Charles Caldwell Nov 11, 2008
    check the condenser and condenser fan for blockage. It may be that the condenser needs to be cleaned or the condenser fan is bad and not working. The condenser-cooling fan, which circulates air over the compressor to cool it, can often be the problem. A humming or clicking sound is a sign of a overheated or damaged compressor.
Fridge not cooling
Sometimes the air duct bewteen the fridge and freezer becomes blocked with snowy ice what forms when the freezer has been running without an operative fan - solution switch the unit off with the doors open for 24hrs then clean close it up and switch it on - if it was snow problem will be gone - cheap and easy to give it a try
Feb 21, 2014 | Electrolux Refrigerators
Cant Get fridge and freezer to cool to correct temp
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Jan 02, 2014 | Refrigerators
Hotpoint rla31 motor constantly running/freezing at the back
Your fridge is cooled by the freezer, the thermostat is within the Fridge to tell it to shut off, you might have a bad fan or a build up of frost where the air is sent to the fridge, check where air goes to the fridge when it's running, if you don't feel air flow then something is up, best thing you can do is take everything out and allow the fridge to defrost, at leat 24hrs. then see what happens, if you don't feel air flow after the defrost then you fan is shot and you'll need to replace it.
Aug 04, 2012 | Hotpoint RLA31 Compact Refrigerator
Used armana bottom freezer fridge, not cooling?
yes leave it on for another 24 hours its probably the settings on the refridgerator
Jul 13, 2010 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Transported a fridge on its side, waited 24hrs, plugged in.
Transporting frig on side probably damaged the compressor due to the oil inside draining from bottom. Do you know if the bulbs were working before you purchased? If they were you may have damaged the door switch, easy fix, just replace. Compressor replacement should be left to a pro. Probably looking at a couple hundred. One other thought is you might have caused a gas leak during transporting, another job for a pro.
Feb 23, 2009 | Frigidaire FRT18G4A Top Freezer...
Frgidaire side by side fridge not cold freezer is good
Fan needs to be replaced. Common issue and easily done. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Frigidaire FRS26ZSG
Fridge and freezer too warm after cleaning
I guess by now you have resolved this.. If you need help please alert me..
If this is unresolved, can you tell me if the compressor runs? According to the Jen air manual I downloaded, you shud be able hear a number of sounds from the fridge, at different stages eg defrost, cooling etc. Obviously you checked the temperature controlls? Door seals Ok? Power,is the light on.. Even if there appears to be power, pls change the power outlet and run the fridge from a different source. Pls advise if you still have problems. Rgds,
May 01, 2008 | Jenn-Air JCD2389G Side by Side...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Nov 07, 2007 | Haier Refrigerators
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Whirlpool ED5FTGX Side by Side Refrigerator Logo
133 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
