Question about Frigidaire Microwave Ovens
Dim control panel unable to read
Frigidare FMT148G1W1 control panel too dim to read in any kind of light. Is there a resistor or transformer tap I can change to brighten the characters in the display? Reseated all connectors on circuit board, inspected board for cold solder joints, swollen or damaged components, nothing found. Is the schematic for the control panel available anywhere?
Thanks.........Pete
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Posted on Nov 12, 2008
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Product is GE Microwave (Spacesaver-type) JNM1731DM1BB. New surface light bulbs installed. Unable to turn them off or change from bright to dim
Bottom lights are controlled through relays on the main control board which is mounted on the back of the touch pads (control panel).You can check and see if wires are touching each other on the board but my guess is the board is defective and needs replaced.
Apr 02, 2015 | GE Microwave Ovens
Blown fuses
Well you certainly have done a lot of work on a microwave that is not worth the effort. When fuses blow and destroy other items ,it is time to junk it and up date. I have found that when something like what happens 9 times out of 10 it will be the magnetron or transformer either of which will be more than 1/2 the cost of a new machine.
May 18, 2013 | Microwave Ovens
Are you able to get a VFD separately for Maytag MMV4205BAW to repair dim display panel without doing the entire panel?
The VFD (vacuum fluorescent display) tube is not available as a separate part for this model, so you would have to order a new control circuit board.
For model MMV4205BAW, the board's Amana part number W10127098 and it runs a hefty $232.30.
BUT -
if you order the board by the original Samsung part number, you can probably get it a for a lot less.
Here is a photo of a similar board which is marked to show you where to find the full part number.
You can find links to helpful exploded view diagrams and part ordering help here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is out, you disconnect the keypad, then take out your old board and put in the new one.
Some connectors may have a lock.
Oct 17, 2012 | Jenn-Air JMC7000 Microwave Oven
Saisho microwave display dim
22ohm resistor on control panel or diode in rectifier short Re: Jeff
Apr 12, 2012 | Microwave Ovens
Replacing the magnetron tube. model FMT148G1W1
http://www.gallawa.com/microtech/mag_test.html
http://www.repairfaq.org/REPAIR/F_micfaq5.html
be very carefull please , the capacitor can easily kill you !!! with the amount of charge it stores
Oct 23, 2009 | Microwave Ovens
Frigidare FMCB115Gc Has power won't start up
Could be a blown fuse in the HV transformer primary circuit,bad connections to the magnetron filament,open thermal protector or thermal fuse,
Sep 03, 2009 | Frigidaire Mid-Size Microwave
FMV145BC1 - Frigidare Microwave will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhdgh
Aug 14, 2009 | Frigidaire FMV145K Microwave Oven
Microwave runs but doesn't heat
If there is no noise at all, this suggests that the power transformer isn`t receiving power from the timer/control panel. If you do hear a little buzz when you operate the microwave, The timer/control panel is operating, However It could be a few things which if you are confident enough to tackle, could be sorted by you but bear in mind that microwave ovens can store a lethal amount of voltage which can kill, about 2000 volts for a year or so. Possible causes of your fault are the Magnetron, Power transformer, Capacitor, Diode or even the control panel that provides power for the power transformer if you don`t hear the buzz. Have you got a meter?? Yes? Switch it to X10 ohms. Next, Unplug from the power socket and remove the casing, discharge the high voltage capacitor with a pair of well insulated snipe nosed pliers covered in a thick dry towel. Next, place the meter leads between the capacitor where the thick lead enters, and the casing of the oven. Does the meter read anything? No? You need to find out if the transformer is receiving power from the timer/control panel. If it is, the Magnetron will be US or the heater supply is missing to the magnetron. If the meter reads, The diode/capacitor or magnetron is short circuit. Disconnect the thick leads which are connected to the capacitor, Check for leakage across the capacitor again, Yes? Magnetron OK. Some diodes are built into the capacitor. On models where the diode is visible, (A black device going from the capacitor to a screw holding it to the casing), either unscrew the screw or disconnect the connector on the capacitor, now read the capacitor connector, if OK, no reading, Diode US, If there is a reading, the capacitor is US. If there`s still no reading, read the lead which you removed from the capacitor which goes to the Magnetron, If it reads, the Magnetron is Short Circuit. To check the heater, connect your meter across the two connectors on the magnetron, If it reads, the heaters are OK, read across the two wires that you revoved from the magnetron, if it reads, the Transformer is OK, if not, a new Transformer is reqiured. If not, they are O/C, New magnetron required. I hope this helps, Ian
Jun 09, 2009 | GE JVM1420 Microwave Oven
GE Microwave Spacesaver shuts down and trips circuit
I would suspect your high voltage transformer has failed. Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 26, 2008 | Microwave Ovens
Microwave Ovens Logo
471 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
