Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Whirlpool Imperial Series -- how to use self cleaning cycle?
Lost the instruction manual. Whirlpool Imperial Series, five years old, smooth stove top range. Can't remember how to use self cleaning? How long does cycle take and what do I do when cycle is complete? Do I keep door open or ajar after cycle is finished? How long before I can use the oven after cycle completed?
heatman101
  • 43501 Answers
SOURCE: I have a Smeg SA130P
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Dec 14, 2010
How do i use my self cleaning oven with model number rf365pxyn
Merry Christmas! Here is a free user manual download for your Whirlpool model RF365PXYN stove including the self cleaning instructions.
https://www.manualslib.com/manual/192853/Whirlpool-Rf365pxy.html
Dec 21, 2016 | Ovens
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I lost my manual n i need a new one in order for the person i kalled to fix it for me to kno how to do it cuz its complicated so he will not mess it up
    I can not get my oven door off on my frigidaire self cleaning stove the stove is about five yars old
    I know it should just slide right out. But for some reason its not sliding of when I lift up on the door.
    Regards
    Kevin
    May 10, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
    My 3 year old barely used Whirlpool Gas Oven has stopped heating. The gas stove top still works. Whirlpool customer service told me to clean out the gas chamber with a pin...there's nothing TO cleanout....
    Just had a repairman here today March 31, 2010 for the same problem. $350 repair bill. There was a short in the gas valve that cause it to go bad and it also blew out the ignitaion computer board. Forget about replacing the ignitor. I already did and that was not the problem. So the qauestion for you is pay for the repair or buy a new stove.
    Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Code : E3 -F1-
    I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
    Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    I have no users' manual and would like the basic instruction for the self-cleaning function
    The only thing I can offer is this: Most electronics cannot recover from the extreme 900 degree temp of self clean cycle. It is therefore recommended not to use the self clean on newer models. Why not get some oven cleaner and do it the old fashioned way?
    Sep 14, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Self-cleaning gas oven
    Door lock motor has probably failed.....Self clean on many
    ovens can be a self destruct mode. Door latch motors, sensor
    probes and even the electronic controls can be destroyed by
    this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
    Jun 02, 2008 | Frigidaire Ovens
    Self Cleaning Cycle for Oven
    I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
    May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
    New fridgidaire self cleaning oven w/ no insturction manual
    its a new oven?? press the clean button the arrow up(the display should read 3:00, press start,the door will automatically lock and your on your way. remember to remove racks first, they will warp and discolor
    Feb 24, 2008 | Ovens
    Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
    597 people viewed this question
    Top Smeg Ovens Experts
    Jason Harris
    Jason Harris
    bosch5
    Are you a Smeg Oven Expert? Answer questions, earn points and help others
