Question about Samsung SyncMaster 920N 19" LCD Monitor
My monitor works fine for 0.5 sec every time I turn on my PC and then nothing
When my computers starts my monitor works for about 0.5sec and after this nothing... The green light shows that the monitor is working fine but I only get a black screen. If I turn off the monitor and turn it on again it works again for 0.5sec and then nothing.. I've tried it in other PCs and it does the same thing. I imagine that the problem has nothing to do with hardware, but then whats the reason?? HELP ME PLEASE
  • apostolhs
    apostolhs Jan 30, 2009
    I fixed my monitor! I don't know exactly how I did it (:
    I just opened it and cleaned the dust and some melted(!) parts from inside and now it is working fine.
    It's been 3 months and I had NO problem since!
    Sarimssk maybe you should try the same thing..
  • Jaxs47 Feb 28, 2009
    up till now I can use my moniter by just unplugging then plugging it back in, works fine afterwords. I'm still looking for the right fix. Till then I have ti use this
And you call that a solution??? I have the exact same problem. And if someone has a real idea about it pls post.
Posted on Nov 15, 2008
    Genius:
  • 1,605 Answers
Sound like the monitor is gone.
if it is still in Warranty, you can call Samsung.
if it is out of warranty, take it to any computer repair shop. (cost may be prohibitive.)
the last option is get a mew one.
Posted on Nov 10, 2008
  • Frank
    Frank Jan 30, 2009
    yes! that is the solution. I can't perform miracle on electronic items.
    if you can, tehn by all means go ahead.
Monitor and keyboard not working
Maybe overheating ? Needs cleaning !
Or maybe it is graphic card... you must see with your servicer.
I can give you this :
turn off laptop, unplug adapter , remove battery, then hold the start key for about 20 sec. and release, turn back computer ion and see if this is the case...
If not :
take it to computer servicer
Mar 06, 2014 | HP Compaq Presario SR1115CL PC Desktop
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Dell monitor will come on but will not stay on. stays on 5sec
5 seconds? Hmm, too long for inverter driver turning into protection caused by bad lamps. Also too long for PWM controller in the switching power supply.
Rather looks like overheating of the FETs in the inverter, they are driving HV-transformers. Open the monitor, remove metal lid and observe inverter board. If PCB under and around these FETs is darkened, replace them.
These Dells hard to open. Take the foot off and unscrew plastic cover. Then using flat screwdriver with wide blade separate plastic halves of the case, starting from bottom edge and moving to opposite. It might be sweaty.
Sep 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
win
if bad monitor start a post how to fix a bad monitor (endless answers)
Mar 20, 2017 | HP vs19 (Silver) 19" LCD Monitor
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Liquid Video monitor goes black after 30 seconds
Capacitors on the power board inside the lcd monitor have blown they can be replaced with new ones and the monitor should return to normal operation.
service center or if you feel capable you can do it your self with a soldering iron and the correct caps that have blown you need voltage and micro faradays usually 25 v at 470 mfd (u)however monitors use different kinds and voltages can be different it will be marked on the side of the damaged capacitors.
l8r
Nov 11, 2008 | Computers & Internet
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
LCD Monitor - green power light blinking - nothing on monitor
Carol,
It sounds like your computer is putting the monitor in power save or sleep mode, and the monitor doesn't respond appropriately. The monitor might be faulty, or overheating. Make sure there is adequate ventilation around the monitor, and that it is clean and free from dust around the vents on the case.
Another thing to try is to check your computer's screen saver and power saving settings. Try turning off the "turn off monitor after [interval]" setting and see if the monitor still shuts off after several hours.
Good luck, hope this helps.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Samsung SyncMaster 740N 17" auto adjustment locked
I just had my Samsung 740N LCD monitor auto adjustment lock 2hours ago.
But i found this cool solution at
www.fixya.com
"Press down
the menu button(1st button on the left) for 5sec or until the menu display gone?"
and it works for me. Hope it will work on you
Thanks
http://www.fixya.com/
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 920N 19" LCD Monitor Logo
456 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
