Question about Video Game Consoles & Games
Mr bean jigsaw
Maybe it's something simple, when doing the jigsaw in mr bean, i can't make the pieces rotate. How do i get the pieces to rotate?
  • Anonymous May 17, 2009
    i cant get jigsaw peices to to rotate either drag and hold down left doesnt work
  • karet May 17, 2009
    drag and hold left button doesnt work any other ideas
  • 470 Answers
Just simlpe just drag it ang hold the left buttom for it to rotate
Posted on Nov 16, 2008
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Dodge magnum idling
Mr. Castillo.
I do not know exactly is your belt diagram, but I will give you a solution based to other vehicle . Since you do have a rattling noise with AC- off, please go to the belt Tensioner which might be a hydraulic one,or with a spring tension. If you do not manage to have a clear picture of it, the advise I give you is a simple long piece of wood and very carefully as the engine is idling,put it to all the parts which are in use at that time,one after the other and carefully not to touch the rotating belt,which might cause you an injury,or damage to the engine parts in that area. The piece of wood when is touched to any rotating part,on the other side of the wood,put it close to your ear and surely you will get the rattling noise easily. After that you will carry the repair .
Good luck and be very careful.
Mar 02, 2014 | Cars & Trucks
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
I have 3 days left to finish this puzzle for a project. i have blown up pics of the box and tried to compare pics what could you recommend i do to get it faster. thanks.
Maybe you should read the tips here:
http://voices.yahoo.com/completing-1000-piece-jigsaw-puzzle-hours-not-1683927.html
http://kerryg.hubpages.com/hub/How-To-Do-Jigsaw-Puzzles-Like-an-Expert
May 19, 2011 | Lincoln Abraham Lincoln Photomosaics 1026...
I have cleaned my machine and put the grinder back inside its housing but it says the grinder is blocked and won't operate. I cannot understand where it can be blocked.
You removed the grinder? Or you removed the outer burr from the grinder? It can be tricky to get back in place with the correct lineup. If you don't do it just right, it won't sit down in place like it is supposed to. Here are the full instructions, you may just need the last little bit about lining the burr up on reassembly.
From wholelattelove website:
You do not need to clean the grinder as often as you may think. Usually we do not recommend cleaning the grinder unless there is a problem with calibration or a clog. Avoiding oily beans, flavored beans, and beans stored in the fridge or freezer will typically prevent issues.
If you do experience issues with your grinder, cleaning it is the most common solution. To clean your grinder, follow these directions:
1. Remove the water reservoir, turn off and unplug the machine.
2. Take the cover off of the bean hopper and vacuum out the beans.
3. Remove the 3 Phillips head screws that are in the bean hopper.
4. Lift up the bean hopper and set it aside.
5. Open the machine's service door and remove the drip tray and the brew group.
6. Remove the rubber gasket from the top of the grinder area.
7. The grinder is made up of 2 pieces. The inner piece has 4 tabs that the rubber gasket sits on. The outer piece has teeth in a ring on the exterior covering ½ the circumference.
8. Rotate the outer ring 180 degrees counterclockwise. You should be able to lift off the inner ring. There is a red spot on the outer collar which should now be facing the 9 0'clock position when you are at the front of the machine.
9. Vacuum out all of the beans and ground coffee.
10. If possible, use a small pipe cleaner to get grounds out of the "pathway" going to the front of the machine. It is located on the floor of the grinder at about the 5 0'clock position.
11. Above where the brew group would be located, there is a gray triangular tab attached to a door on a hinge. Pull down on the triangle - coffee grounds may come out.
12. Look above the trap door and you will see the other end of the chute. Vacuum out the chute and clean with a pipe cleaner.
Reinstalling
1. Drop the inner burr onto the grinder with the tab that has the red and blue marks facing the right hand side of the machine at approximately the three-o'clock position.
2. Rotate the outer collar so that the red mark lines up the red/blue marks on the inner burr.
3. Reinstall the rubber gasket that goes over the grinder. The slots in the gasket line up with the four tabs of the outer burr.
4. There is a straight piece located directly to the right of the grinder. This is your dosage control. There is a piece that can slide backwards and forwards on this dosage arm. Push this arm all the way to the back of the machine.
5. Set the knobs in the bean hopper to #0 on the grind setting knob. Set the doser knob all the way to the plus setting. Now place the hopper back into the machine.
Note: You may have to rotate one or both of the knobs, a small amount, to get the bean hopper to set down on its supports.
6. Install the 3 screws.
7. Replace the water reservoir.
8. Fill the bean hopper with a cup of beans.
9. Plug in and turn on the machine.
10. Reinstall the brew group and the drip tray.
11. Once the machine warms up, press the small coffee button. When the grinder comes on set the grind setting to 6.
Note: You may have to press the small coffee button twice or 3 times before the machine will make a cup of espresso.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
How do i reset my gaggia titanium, the gears are in the wrong position
Are you talking about the coffee brewing system? Or the coffee grinding system? You said "gears" so it sounds like you took the coffee bean hopper out and the adjustment knobs come out with it. So if you are trying to line those gear teeth back up correctly, Here is the complete instructions for cleaning the grinder (from wholelattelove.com). You only need the last few steps for lining up the gears.
Reinstalling
Sep 24, 2010 | Gaggia Titanium Espresso Machine
Replacing blade?
at the top and front of the saw there is a plastic handle. Pull up and rotate counter clockwise 1/2 or full turn maybe more. remove and replace blade and rotate clockwise (handle) and push it back down.
Jan 03, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
Video Game Consoles & Games Logo
354 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
