Question about Lucent AT&T 960 Corded Phone
Display issue A number of time when we get an incoming call the display on the phone starts blinking with what looks like squares. In order to fix I need to disconnect the power from the phone, remove the batteries, put them back in and then reconnect power. What can be causing this and is there another way to correct?
  • mnswede Jan 02, 2008
    I have nothing to add, except that my problem is exactly the same and my process to reset it is the same. I've had this issue for years, and it has nothing to do (as far as I can tell) with battery charge level. I have two of these phones and it happens to both of them, but not at the same time in the same household, and connected to the same line.
    Habit-Forming:
  • 68 Answers
This happens on our AT&T 962 & Lucent 965 telephones. The phones don't all do it at the same time and the only way to clear the trouble is to unplug the telephone, remove the batteries and then put everything back together again.
Posted on Oct 29, 2008
When a call comes in, it shows my number
Is this happening just to you or are other employees experiencing the same issue? - it's nothing you did - These days it is very easy to "SPOOF" the calling party number to display whatever the caller wants it to display. If it's occurring on all of your incoming calls then contact your PBX system support person/company.
Jan 08, 2014 | Mitel Superset 4025 Corded Phone
Phone Model # KX-TGA101S I bought this dual phone last year. Since last 4 days on an incoming call phone does not ring. Also the date and time display has disappeared on the screen. Every time on an...
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 17, 2011 | Panasonic (KX-TG1032S) Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
External caller ID does not display on either line talkswitch 284
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Jun 18, 2009 | TalkSwitch CT.TS001.124001.US...
How get do I get my incoming phone numbers to be displayed
Most phones will only do what you require if the contacts are stored on the phones memory instead of the SIM memory. This will also prevent you from assigning photos to contacts and one touch speed dials (i.e. press and hold a number to dial a stored number) Try copying all your contacts to the phones memory. If you see duplicate names, go into phone book settings and adjust setting for phone just to look at phones memory and this will stop duplicates being shown. hope that helps?
Apr 26, 2009 | Nokia 6600 slide Cellular Phone
Mobile is glowing for every incoming message/incoming call
You haven't said about your mobile model.
Moreover, these blinking will come when you keep your mobile in silent/vibrating mode.
Anyways, if you are getting disturbed by the blinking of the display in the nights, then keep your mobile upside down.
Feb 07, 2009 | Nokia N72 Cellular Phone
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
Lost the time and date line in the display
Unplug the phone, wait one minute, then plug it back in and see if the display comes back on. Press the program button, press 22 on the dial pad, press program button again ( if the phone is ringing on the incoming call and not just flashing).
May 31, 2008 | Panasonic KX-T7630 Corded Phone
Lucent AT&T 960 Corded Phone Logo
115 people viewed this question
Top Lucent Lands Phones Experts
Marvin
Marvin
vince
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
