Question about Brother Office Equipment & Supplies
I NEED THE MAC ADDRESS OF MY NEW MFC-490CW AND I DON'T KNOW HOW TO FIND IT. I HAVE A MAC AND WEP ENCRYPTED NETWORK.
  • Anonymous Feb 03, 2009
    cant seem to find the mac address...
Try going to the web interface which you can do by typing in the ip address of the printer in any browser
Posted on Nov 10, 2008
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
My wii is not signing on line error code 51331 is a it says please help
Hello xklown777
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
Log into the router using the default IP (if you don´t know this, consult your router's manual for assistance). Locate the "wireless security" section of your router settings and find the WEP or WPA key.
If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
If you are using WPA, the Wii console is compatible with the following types:
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
3. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
The above steps usually resolve the problem. If the error message still comes up, there are other ways I can help you, but it would help if you could tell me the model number of your router, as some models have compatability problems with the Wii.
Hope this helps.
ajblaj
Sep 17, 2010 | Nintendo Video Game Consoles & Games
I am trying to connect to internet the screen says erro code 51330
Hello val171156
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
Hope this helps.
ajblaj
Sep 14, 2010 | Nintendo Wii Console
What is error code 51331?
Normal.dotm 0 0 1 253 1446 Statens bygningstekniske etat 12 2 1775 12.0 0 false 21 18 pkt 18 pkt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Vanlig tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;} Hello rb_singer
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
Hope this helps.
ajblaj
Sep 13, 2010 | Nintendo Wii Console
How do I switch on WEP encryption to prevent my
please follow steps to fix issue
1.connect WGXB102 to computer with CAT5 cable
open setting page of device
2.open internet explore type there:192.168.0.101
user name "admin" password is "password"
3.under setup click on wireless setting now you can click on WEP then type security
reagrds
prakash
Jan 23, 2010 | NetGear WGXB102 (wgxb102na) Ethernet...
Need encryption code...
here is a trouble shoot guide for your problem. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Mar 03, 2009 | Dell TrueMobile 2300 Router (000001)
Securing my wifi network
Hi George,
Simply open your Internet browser, in the address line, inset 192.168.0.1, then:
-> Goto TOOLS
Here you set the administrator password, note that you have to set the same password twice.
Do set some security as well, other vice your neighbor will use your network, - and that you don’t want, as you don’t know what and where he go on the internet.
On page 27 in your manual, you find the way to set the wireless settings.
On page 37 in your manual, you find a way to set MAC address settings. Thise settings allow only those MAC addresses as you put in the table.
You find your own MAC address like this:
->Start->run->write cmd and hit enter; a black DOS window open, write ipconfig /all (note the space before /all). Here you find your MAC address – note that there is two cards in your laptop, and the card you want the MAC address for is the wireless card.
regards
Teis
plz let me know if you need furter help.
Jan 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
323 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
