Question about Dishwashers
I HAVE THE CABLES TO FIX MY DOOR ON MY DISHWASHER, I NEED A DIAGRAM TO INSTALL THEM MY SELF, CAN YOU HELP ME, MY DISHWASHER IS 1989 AND MODEL @GSD640G
  • 3 Answers
I HAVE THE CABLES TO - e5881e5.jpg This is the best picture I could find. I hope it helps!
Posted on Nov 15, 2008
Lift master cablesi removed the cables and doors sectional doors to fix .how do i set the tension. and the roller brackets is there a diagram to tell how to install,there a two holes and i can't...
Please do not attempt to set the tension your self. Call a garage door service Co. Broken arms and fingers result. It is not worth the attempt. Those tension spring do all the lifting of the door and have to much torque to mess with.
Jul 21, 2011 | liftmaster Garage Door 1/2 Hp
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Jun 20, 2011 | Whirlpool Dishwashers
How to remove the door panel on 1991 mercure cougar. I need to replace window motors.
DOOR TRIM PANEL
1989-92 Models
(see Figure 8 - click over pic for zoom)
  1. Remove window regulator switch housing.
  2. Remove the door inside handle cup (snaps out).
Fig. 8: Door trim panel-1989-92 models
  1. Remove the self tapping screw retaining door trim panel upper front extension assembly, and remove assembly.
  2. Remove the two self tapping screws retaining door trim panel to the door inner panel.
  3. Lift the door trim panel upward and snap out trim panel.
  4. Disconnect the wire harness for courtesy lamp.
To install:
  1. Attach the wiring harness to the courtesy lamp.
  2. Place the door panel into position, then tighten the panel to the inner panel.
  3. Attach the upper front extension assembly.
  4. Snap the door handle cup on the door assembly.
  5. Install the window regulator switch housing.
Electric Window Motor
REMOVAL & INSTALLATION
  1. Remove the trim panel and watershield.
  2. Remove the speakers.
  3. Disconnect the negative battery cable.
  4. Disconnect the motor wires and the connector.
  5. Using the dimples located on the inner door panel, drill 3 / 4 in. (19mm) holes for access to the motor.
WARNING When drilling the holes, the glass must be in the up position. The hole saw pilot must not extend more than1/4in. (6mm) beyond the hole saw.
CAUTION Secure the regulator in a vise and drill a5/16in. (8mm) hole through the regulator sector gear and the plate. Install a1/4in. (6mm) bolt and nut in the hole to prevent the sector gear from moving when the motor and drive assembly is removed.
  1. Working through the holes, remove the 3 motor and drive-to-regulator attaching bolts. Remove the motor and drive from the door.
To install:
  1. Clean the chips of metal from the surrounding area. Then coat the bare metal to avoid rust.
  2. When installing the motor and drive to the regulator and install the 3 screws just snugly enough to hold it. Remove the regulator restraining bolt and nut if the old regulator was re-used.
  3. Connect the negative battery cable.
  4. Connect the wires and cycle the glass through its run to ensure gear engagement. Then, tighten the attaching screws to 50-85 inch lbs. (6-10 Nm).
  5. Install the speakers and door trim panel with watershield.
Hope helps (remember rated this).
Jun 25, 2010 | 1991 Mercury Cougar
Leaking door
They had a big problem with this model leaking at the corners of the doors. I would replace the baffle (part# 154576501) and install a splash shield kit (part# 154701001, comes with instructions)
Apr 07, 2010 | Frigidaire PLD4375RFC Dishwasher
Dishwasher door falls quickly
Go to partsselect.com they should have the parts and diagrams of the parts and where they go. Just type in model number. The part your looking for holds the door cable that attaches to the door sping. If you'll pull the dishwasher out you should be able to access it.
Jan 24, 2010 | GE 25 in. Profile PDW8200J Built-in...
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Dishwasher door, too much spring
YES after you have the panel installed it will open and close much better the factory sets the springs on your model tight so when the panel is installed it can weight down the door after the panel is install you may have to readjust them tighter again
Feb 23, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
