Question about Sony UVW-1800P VCR
Is the top and end sensor supposed to be off in servo check mode
Am running checks to hopefully correct no video output after a wrong tape got stuck in unit. Am in servo check mode and it's doing top/end sensor check and both sensors show being off, is this correct? and i presently have a tape in unit,
thank you for any help
  • carlv Nov 10, 2008
    Okay thanks appreciate that. I removed the tape and both sensor's remain off
    no voltage at ir led's
  • 10,594 Answers
If the tape is inside, both sensor should be OFF because both are photo diodes and will ON when receive Light.
Tape inside covers both sensors, so no light, no ON signal.
Posted on Nov 10, 2008
  • Shahid Electronics
    Shahid Electronics Nov 10, 2008
    No tape inside and sensors OFF, then check Infra Red LED mounted at center of both sensor to pass light when needed, this seems not working. Check volts on IR LED.
    I think IR diode supply will turn on when there is a tape inside the unit.
    Do you have dummy tape to check? Dummy tape is used to test loading and unloading of mechanism.
Tape In light flashes every ~0.8 seconds even though no tape in there.
You have got yourself into a tricky mess there. The mechanism was set up in a certain way. When you extracted the tape, it sent the mechanism into the wrong position. There is also a switch called a mode switch that is linked to the mechanism and the electronics of the video. This switch tells the electronics what mode the video is in - IE: fast forward etc. This is now out of position and the whole mechanism needs to be set up in the correct position, assuming there is no faults, and so does the mode switch.
However the bad news is that unless you have the service manual you have little chance of setting it up right. Most video's for example are NOT set up in the eject position for a start, so unless you have the instructions, you will never get it to work right.
Jul 11, 2015 | Emerson EWV601B VCR
Ag7750 stuck in still error 5
Transport mechanism problem if tape will not ff/rewind----possible drive belts or the direct drive idler wheel that moves the tape.
Oct 31, 2012 | Televison & Video
My child got the video stuck i got it out but it wont go back in and play and pwr in red is showing can u help please
This can be due to many faults and need a full check up but I can fill up with few tips.
1. If the cassette does not loads ,then the loading section can be faulty as the load motor or the load motor drive can be faulty.
2. If the cassette in take up tray was removed this would create a wrond setting and so the MODE detect will work differently - check these which are opto devices or proximity sensors/magnetic type.
3. Check for fault in the capstan drive or the SERVO section as it will not power the set but trips off if there is a short.
4. Defective HALL IC can shut the switching and so the servo will shut down the processor.
5. Fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
6. Finally if the loading is not to the MODE switch point or failure of mode can make the loading to trip as it will not complete the load to the desired point.
Aug 24, 2011 | Philips VR540 VHS VCR
Panasonic vcr nv-hd650 stuck tape in machine
1. If the cassette loads and the take up spool does not turn then the machine will shut and rewind.
2. If the take up spool rotates but then it shuts down then the reel sensor at the bottom of the forward wheel can be faulty- there are opto devices or proximity sensors/magnetic type.
3. If the drum does not rotate it will shut down as well a fault in the SERVO section.
All the above issues can stall the loading of the tape and so will be seen as struck inside. Sometimes mechanically/manually removing by unwinding the motor can release a jamming and restore.
Jul 26, 2011 | Televison & Video
My sanyo 670 vcr player tape does not play,rewind or forward. It does just create some ratting sound and stops.
This sound like you have a tape stuck in the VCR. you should goto a Video engineer to get it taken out. And then check it out to see what is going wrong.
hope this helps
Apr 13, 2011 | Sanyo Televison & Video
My Panasonic NV-SD250 VCR displays FO4 message. The unit refuses to eject tapes.
Possible fault with the failure of the servo system, the mechanism , front loading and forward loading or the failure of the drum servo/capstan servo.
You can remove the front panel and top panel and remove up the loading mechanism by unscrewing the mounting. carefully disconnect the cylinder head strips, the audio connections and remove. manually turn to unload off the tape. then check for belt failure or visible errors. Now set back use a dummy cap to cover the end sensor emitter at the centre and manually push the loading mechanism assisting . If there is no loading the capstan is faulty, if it loads and the drums does not work it is tthe cylinder servo.
You will need some knowledge of the circuits to proceed to the correct fault.
Sep 01, 2010 | Panasonic Televison & Video
I have a Zenith VCR/DVD XBR716 and I don't know how to record from a video onto a dvd. I tried doing it the way the manual says to and the light goes on as if it's recoding but in the end the dvd is blank....
Hi I am vortash sounds to me as if you are not switching to the correct source for your recording .. make sure that the DVD is in the the record mode and the source is from tape and not aux or tuner and make sure that the VCR is in the correct playback mode to DVD and finaly the Tape you are trying to record is not carrying an elctronic watermark to prevent recording ... Hope this helps regards vortash
Jul 22, 2009 | Televison & Video
I have a sony bvh 2830 video tape recorder...it been working great but tonight its screwerd up....the video out has snow in it as it should not when its in the stop mode...when its roling tape all that on...
Hi Steve, are you using the internal TBC cards or an external (BVT2000)? What's the condition of the demod output as opposed to watching timebase corrected output?
May 08, 2009 | Televison & Video
No video but have audio
with no tape in the unit, the tape top/end sensors will be "off".
Jan 08, 2009 | Sony UVW-1800P VCR
Doesn't repond to buttons and stuck on rewind
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but one of the reel
Nov 29, 2005 | JVC HR-VP670 VHS VCR
Sony UVW-1800P VCR Logo
135 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
