Question about Cameras
I have a sony handycam dcr-hc20 with a cracked lcd screen. I am trying to purchase a new screen and repair it. Is there a mannual or something I can look at on how to repair the lcd screen and maybe somewhere I can purchase a new screen?
  • 10,594 Answers
You need LCD901 as shown in below exploded view of DCR-HC20
Part number is as follows...
LCD901 " 8-753-205-50 " ACX528AKP-J
This part is available in Part Store.
Need further info / help, let me know.
Thank you.
Posted on Nov 10, 2008
  • sowa_46 Feb 25, 2011
    Part number 8-753-205-50 has been substituted with 8-753-214-28 but this is NLA
The touch screen calibration on my Sony DCR-HC20 doesn\'t work? I keep touching the little \'x\' and it keeps asking me to do it in all three places but never completes the calibration process and the...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Nov 16, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
My SONY HANDYCAM DCR-HC26 touch panel is not working n m unable to forward,rewind,play,or do anything...how do i fix this problem..plzz help..its urgent...
Most likely, the flex cable that runs from your LCD to your main PCboard is bad. The only thing that you can try to do is flip your LCD around and against the camera. See if the touch screen will work then. The camcorder will still need to be repaired by an experienced technician at some point.
Hope this helps.
www.austintelstarservices.com
Oct 02, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
I have a sony DCR-HC20 Handycam, the screen
Hello Gary, sadly lots get the LCD screen go wobbly on the camera types you have, Sony did do a recall on the problem, did you register yours? if so you could have mislaid it.
I had to send my Sony for repair as it went same as you camera has.
Cheers,
David
Jun 06, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
Lcd screen is blurry on my sony handycam dcr-hc20
This does not sound like a CCD problem yet, but a LCD problem. This would require you to replace the LCD screen. Sounds like the LCD inverter is shot. That is the power supply that is required to back light your LCD.
Before we blame that, you should make sure that all ribbon cables are secure and tight.
Good luck !
Feb 04, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
DCR HC20 The touch screen does not work. I went to the calibration screen and pressed the "x" like the manual told me...It does not work too, Please help
I believe the flexible cable from the LCD screen to the main control was cut or lose because the action of open and close the LCD, in any case It require a qualifier Tech trained from Sony to replace this FC
DO NOT tampere it, You might damage the LCD screen
Dec 09, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam
Its problem of bad ccd imager in your Sony DCR-HC20 camera and this part need to be replaced.
Sony has announced free of cost repair for subject problem in DCR-HC20. Click Sony Support for further info.
Thank you.
Oct 24, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
LCD Touch Screen
Connecting flexible wire between LCD and main board of camera seems cracked/ broken. Please replace it with new one.
Jul 31, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Nothing in viewfinder or on screen
Same thing happened to me. Seems to be 'common' although Sony says they have no recall on the CCD. Look around the forum and you will find others with the same problem.
May 24, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Cameras Logo
362 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
