Question about Microsoft Outlook 2003 for PC
Microsoft exchange server problems
Can not send pictures thru outlook, outlook express, microsoft manager, although outlook is a email provider. i keep receiving the massage: micosoft exchange server not connected to outook or vise versa. also, names need to be underlined in the micro and outlook box with addresses to be checked, which they are there, however not underlined and never check out because to the massage microsoft exchange server etc. is there a simple solution to this head ache? please, inform me as to whats going on.
thanking you in advance,
frank.guerassio@comcast.net
    New Friend:
I can't sync my contacts with my pc its show the msg like micro soft exchanger is unavailable what can i do further?
Posted on May 20, 2013
    New Friend:
  • 144 Answers
Delete the email accound and create it again but dont check the exchange option. Use POP3.
Posted on Nov 10, 2008
How do I change my wife's email user name?
Here is Microsoft forum on the error code
Windows mail error code 0x800ccc90
Cause for this error is generally The client is trying to use Secure Password Authentication and it is not enabled on the Exchange Server computer. To verify what form of authentication the Outlook Express client is using, in Outlook Express, on the Tools menu, click Accounts, and click the Server tab for the account that failed.
Also when your adding the 19 to the email it is creating a whole new email. So if you created the new email. then please refer to this link
POP3 Outlook Express error 0x8000CCC18 and Exchange Server
Aug 10, 2014 | Microsoft Outlook Express
Microsoft outlook menu missing
The "Out of Office Assistant" is a Microsoft Outlook feature that allows users to send automatic replies to people who send emails to them when they are out of the office or otherwise unavailable.
This feature is only available to Outlook users with Microsoft Exchange Server email accounts. Most personal email accounts through home Internet service providers do not support this feature.
If your Out of Office Assistant is missing from your "Tools Menu," it may be disabled, turned off or not installed.
Confirm that the Out of Office Assistant is installed and turned on.
To access the "Out of Office Assistant" menu command, you must be in mail view. It is not accessible from "Calendar," "Tasks," "Notes" or "Journals."
From your Inbox, click "Tools," "Options," the "Other" tab and select "Advanced Options."
Click "Add-in Manager" and select the "Exchange Extensions Commands" check box.
Try to access your "Out of Office Assistant."
If the Exchange Extensions Commands" check box is not available in the "Add-in Manager," proceed to Next Step .
Check that the "Exchange Extensions Commands" are enabled. Click "Help," then "About Microsoft Office Outlook" and select "Disabled Items."
If "Exchange Extensions Commands" is set to "Disabled," select it and click "Enable."
Attempt to use the "Out of Office Assistant" command. If it's still not available, proceed to Next Step .
Install "outex.ecf." From your "Tools" menu, click "Options" and select "Add-in Manager."
Then click "Install" and select "outex.ecf."
Click "Open."
Try to use the "Out of Office Assistant."
If you are still unable to use the "Out of Office Assistant," contact your system administrator.
Troubleshoot the Out of Office Assistant
http://office.microsoft.com/en-us/outlook-help/troubleshoot-the-out-of-office-assistant-HP005242235.aspx?CTT=5&origin=HP005242238
Apr 22, 2013 | Microsoft Outlook Express
Microsoft Web Access won't send mail
If you are trying to send or receive an email in Microsoft Outlook and the password doesn't work, you can check a number of different things. Microsoft Outlook validates your email account with your email provider using various settings. Once it has validated your settings, it will send or receive email. It is not only useful to set up your email correctly but essential if you wish to use Microsoft Outlook.
Gather all of the email settings for your email account. These will be located on your email provider's website in an FAQ or support section. If in doubt contact your email provider to provide all of the settings. Look for any of the following terms: POP, SMTP, IMAP, SSL, SPA, server, and port number. Make a note of all of these. Determine when the problem exists. Check if the problem occurs when sending an email, receiving an email, or both. If the password error only happens with either sending or receiving, this narrows down the source of the problem. Click "Start," type "Outlook" and press "Enter" to open Microsoft Outlook. Click "File > Info > Account Settings." Select your email account and click "Change." Click the "Incoming mail server" field, if your error was when receiving email but not sending. Enter the full "incoming mail server" address as provided by your email provider. If your email is "IMAP" then change the "Account Type" to display "IMAP." Click "More Settings > Advanced." Make sure that the incoming server "Port" number is the same as your email provider stipulates. If your provider requires SSL, then click "This server requires an encrypted connection (SSL)." Click "OK." Click the "Outgoing mail server" field, if your error was when sending email. Enter the full outgoing server address. Click "More Settings > Advanced." Make sure the "Outgoing server" port is correctly set. If your email provider requires encryption, then select the correct type from the drop-down menu. Click "OK." Click the "password" field and make sure you have entered the correct password. If your mail provider requires "SPA," then click the "Require logon using Secure Password Authentication (SPA)" to enable it. Click "Next" and then "Finish." Your password should now work. Hope it helps.
Aug 07, 2012 | Microsoft Exchange 5.5 Outlook Web Access...
Email problems: error code 0x800CCC0F,
When you use Microsoft Outlook Express to send and receive mail to a Post Office Protocol 3 (POP3) or Internet Message Access Protocol (IMAP) server running Exchange 2000 Server or Exchange Server 2003, you may receive the following error message. Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity.
Sep 29, 2011 | Microsoft Internet Explorer 7
My computer has Vista and Outlook Express. Problem when I am in some motels on wyfi I can get the internet and my email but can not send out emil. If I go to my providers web site and then go to my web...
Are you able to surf the net using the WiFi (when the evdo connection has been closed via comm manager)?
If you're online with WiFi, but can't send email (yet you can receive), I'm guessing that the WiFi's internet connection may be the culprit...
You see, many ISPs have outgoing mail filters in place so that viruses and the like can't send out spam from multiple computers.
For example, my provider is optimum online, and they only allow outgoing mail traffic on port 25 (the standard pop3 outgoing port) if it is going to mail.optonline.com.
All you have to do then, is change your outgoing mail server to optonline, and you're all set (note this doesn't change your email address... all outgoing mail servers are the same, you can use whichever you want and it won't have any effect on your name or anything). Every optonline user in my area knows about this by now.
Problem is, then you can't send email from EVDO because optonline isn't accessible from there.
I chose to only send and receive email from the EVDO connection (you can set this somewhere, although I don't remember where), so even when using Wifi, outlook is using the cellular connection.
Alternatively, you can use an exchange server which won't have this problem (since it doesn't send outgoing mail directly, but rather syncs with a server which then sends your mail). special thanks to: dishe
Mar 11, 2010 | Microsoft Computers & Internet
Am tring to set up my email on my new note book in out look express but dont seem to be able to come up with the log on page so am not able to do any thing like send an email can use email on my hotmail...
Outlook Express needs you to have an email account with your ISP, and your ISP should provide you with the setup items like Mail Servers. Once this isw done, you will have complete access to your email.
As an example, my ISP is Comcast and my mail servers are
mail.comcast.net to receive, and
smtp.comcast.net to send.
Your ISP will have their own servers, of course.
You will need to log in to these servers, using logins and passwords provided by your ISP. Outlook Express manages this as well.
Oct 30, 2009 | Microsoft Outlook Express
Exchange not sending/receiving emails
Hiii,
You need to first check all connector related to Emails, if they are working properly. You can check receive connector by going into Server Configuration then Hub Transport and then you will see Receive Connectors are listed at right side below to server name. Just enable all receive connectors.
exchange-not-sending-receiving-emails-w3i35ygaym0a2mtgexp5w2fh-2-0.png You can check for send connector in Organization Configuration then Hub Transport and then at right side in Send Connectors Tab. exchange-not-sending-receiving-emails-w3i35ygaym0a2mtgexp5w2fh-2-2.png Enable all send connectors. Now check for services by going through Server Manager in start menu. In server manager window Click on Configuration then click on Services. You can check below displayed image of server manager for details.
Now check for send / receive.
exchange-not-sending-receiving-emails-w3i35ygaym0a2mtgexp5w2fh-2-5.png If you are still getting send / receive error then defragment exchange database edb file.
You can defragment edb file using Exchange Management Shell by executing this command:ESEUTIL /d "c:\edbfilename.edb" you can see its in displayed image. Now check for send / receive mails.
Jul 29, 2009 | Microsoft Computers & Internet
I want to scan and email a document from my new HP DESKJET F4280 printer. I can scan it, and then I try to share it, but when I hit the send button it says there is no internet connection. Am I right in...
When you scan a document it must be scanned with OCR software. The default scanning method will scan a document as a picture, not a document with letters and words. The OCR software will recognize the letters and put the scanned document in the proper format to open it with MS Word. The software that you scan with should have a setting for OCR, read your instructions or help files to get the details if you can not find them very easy in the software you use for scanning. .
The problem with using Outlook may be that you have not set it up properly to get your emails from your email server. You do not need to use Outlook or Outlook express to send any documents, you can use your web based email server if you like, but you can use Outlook Express as well. You just need to add the document to send as an attachment to the email.
To set up Outlook Express to get your email, you must first find out what the POP3 and SMTP setting you must use. You can get that information from your email provider, it is different for every email provider. Then you go to the "File" menu at the top left of Outlook Express and select "Identities" and select "Add New Identity" and from there you will go thru a wizard to guide you thru the process of setting up your email client. Just make sure you have the POP3 and SMTP settings available for you to put into Outlook Express when prompted to in the wizard.
Dave
Nov 13, 2008 | HP Computers & Internet
Microsoft outlook problem.
Well, it depends on the version of MS Office you are using....and to create an outlook express account, you need to have a .NET account for microsoft and you can sign up for this using your OS itself...try doing this and you should be able to use MS outlook express.
Oct 25, 2008 | Microsoft Windows XP Professional With...
Unable to send email more than 3mb by outlook express
there will be a restriction in your office , restriction can be made in exchange server
Mar 25, 2008 | Microsoft Windows XP Professional With...
Microsoft Outlook 2003 for PC Logo
116 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
