Question about Euro-Pro Shark 80 - 7133
Fabric not moving forward
The thread dogs do not seem to be working properly to move the fabric forward
  • therevsquilt Apr 22, 2008
    Dog feed not working. Stuck in down position. Lever goes to up position without working the system. Sent to Manuf for Manuel. Has no info in it about use of variety of stitches. Set on stitches K-O does not yield pictured stitches.
I think I have the same problem, my machine only works in reverse, I am so confused, any ideas
Posted on Sep 08, 2008
In can not re thread my bobbins what do i do
Posted on Jul 27, 2008
My Elna 6000: the needle does not want to move forward or backwards
The needle never moves forward/back on its own for most sewing machines. The needle bar goes up and down. The fabric moves due to the action of the feed dogs. First remove the fabric from under the presser foot. Check for tangled thread wrapped around the feed dogs or fabric/thread going down into the bobbin area in a tangle. Next check if the feed dogs are up. (When the feed dogs are down or covered (on some machines), the machine is in darning mode. The fabric will only move if you move it yourself.) With the fabric out of the way, rotate the hand wheel and check if the feed dogs are moving. Open up the bobbin compartment and clean out any lint, thread or other debris that may be tangling the mechanism. Take off the throat plate and check the feed dogs. A damaged throat plate can stop the feed dogs from moving properly. You may need to replace the throat plate.
For some machines, you may need to make sure that the unit is not in bobbin wind mode. This is usually obvious since the needle bar won't move either.
I hope this helps.
Jul 16, 2018 | Elna Sewing Machines
ELNA 1000 not moving fabric through.
Have you got a tangle under your fabric? If so, release the fabric and rethread your machine, making sure the foot is up during threading. Otherwise check the feed dog under the foot. There's usually a switch somewhere that brings the feed dog up or down. If it's down the fabric won't feed. Another point, what type of fabric are you sewing. If it's leather or leatherette you'll need to use a roller foot. Hope this helps.
Oct 03, 2017 | Elna Sewing Machines
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Feed dog not moving fabric forward
it would be a good idea to have the feed dogs checked to see why
they are not moving the fabric
Jan 07, 2013 | Brother XL-6562 Mechanical Sewing Machine
I have a JukiLU562 and fabric won't move starting to sew
the feed dogs are what move the fabric thru the machine to sew it
if the feed dogs are not working, then they need to be checked
to see if they have some loose or broken or need to be retimed
Jun 05, 2012 | Juki Sewing Machines
Feed dog not moving
if the feed dogs are not working correctly, then the machine needs to be serviced
Mar 10, 2012 | Sewing Machines
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Machine works but doesnt move forward
Could be that the feed dog is in the down position. The feed dog consists of serrated sections which move together under the fabric and move it under the needle. Run the machine unthreaded and you should see the serrated sections lift above the needle plate, move forward and then drop again. If this doesn't happen the "drop feed dog" knob on the front of the machine could be pushed in. Look for a small knob about 1/2 inch across on the right front of the machine. Push on it and move it sideways at the same time. If it pops out this means that the feed dog is now up and you should be able to sew.
Aug 26, 2008 | Husqvarna Viking 1
Euro-Pro Shark 80 - 7133 Logo
161 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
