Question about Samsung DVDR120 DVD Recorder
I am having problems hooking it up to an HD Receiver from Direct TV
I can play DVD's, but I can't record. Any thoughts? There is no RF Out on the HD Receiver.
  • Anonymous Jun 11, 2008
    mi problema es que mi dvdr130s no lee el disco
Pitch it
Posted on Jun 29, 2008
    Problem Solver:
  • 10 Answers
Playback and record are 2 different things. playback, you connect the DVD player audio-video OUT to the audio-video IN of the TV. recording, you connect the DVD player from the audio-video IN to the audio-video OUT of the source (i.e. cable box, set-top box, etc) hope this helps!
Posted on Sep 13, 2007
SOURCE:
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Connect satellite receiver to dvd recordrer
there is really no way around it. Directv and Tivo are releasing a new receiver in a few months. Or you could purchase a HD dvr. Directv's receivers dont send any guide data thru a RF output, only picture and sound. The recorder you have is great for cable.
Jan 06, 2009 | Televison & Video
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 20, 2008 | RCA RTD155 System
New hdtv
First off, scart has an auto detect feature across pin 8, HDMI does not. If you have turn your TV to the HDMI channel, and at some point turn off the HD source device you are going to get a blank screen, you have to manually turn your TV back.
In regard to whilst you are recording it sounds like you may have tuned in channels on your DVD but not your TV.
Do you have an RF aerial lead connected from the DVD output to the RF on you telly?
Do you have a sky/cable box connected to your TV via scart?
Does the DVD have DVB (digital video broadcast) if so and you have none of the above that is the problem, any tuner running off a single RF lead can only record/play 1 channel at a time. If you have no RF lead going to the TV, then the TV cannot show any terrestrial channels.
Jun 15, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
New TV hookup
Erica,
You should have no problem with this. I have provided a picture of your model below for clarification. One end of the coax will attach to the 3-4 OUT on the back of the receiver and the other end will go to the NEW tv's coax input. If your set has two coax inputs you may have to select the port that you connect to in the menu portion of the tv. If the new tv does not have a coax input you can use RCA jacks which are red/white and yellow and connect those to the TV 1 output on the back of the receiver and the other end to one of the inputs on the back of the tv- this will require you to select the input source you connect to again e.g AUDIO 1, AUDIO2 etc. If you have a VCR run the coax from the 3-4 on the back of the receiver to the antenna inon the back of the VCR -usually the top port, then run another coax from the output- bottom port to the coax input on your tv. I hope I have been of some assistance to you and Thanks for using Fix Ya. If I can assist you further please let me know.
Jim
Apr 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
Feb 26, 2008 | RCA RT2350 System
Samsung DVDR120 DVD Recorder Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
