Question about Dometic RGE400 Top Freezer Refrigerator
Info on replacing drain hose on dometic model 2652
Need info on replacing drain hose on Dometic model 2652 refrigerator Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 3 more comments
  • allendcarter Aug 15, 2010
    Thanks for the info. Taking the fridge our seemed like overkill, removed the old clamp and hose with a long (16") common screwdriver and used a piece of 2" pex tubing, which when heated slipped over the nipple, then a 90' angle and a tail piece to suit. Assembled the pex 2" piece, 90" angle and tail prior to slipping onto the nipple. Pex sticks out through the existing vent holes, however, it's blue (paint to suit if it suits). Probably look a lot less time.
Place heating element on dometic 2652 . The 2 heater leads j7 and j8 need plugged back in. Does it matter which goes where? they are both black wires
heating elements are simply resistance wires and allow current flow in either direction
so there is noconsideration for polarity
either way will be correct
Mar 08, 2016 | Dometic RM2652 Refrigerator
How to convert 110v to 240v dometic 2652 fridge ?
Simple solution would be to step down the 240V to 110 V with a transformer .
Jul 01, 2014 | Dometic RM2652 Refrigerator
My dometic model #2652 has no electric,why??
Check the fuses on the lower back of the unit. There is a control board with them on it. If the fuses are good, you will need to replace the control board. Here is the manual for that unit.
Here is the control board in case you need to order it.
Nov 09, 2012 | Dometic RM2652 Refrigerator
Dometic RM 2652 Doesn't Cool smells of amonia
There is a recall on this product. Go to www.Dometic.com and look for the recall info...or try this link http://67.238.126.140/recall.php put in your model and serial number to see if yours if a recall...I believe it is and I have found the problems you are talking about at this website http://www.gasrefrigeration.net/Why%20they%20fail.htm. which is exactly why they are recalling this model refrigerator. Hope the links help...if not go to the first link and look for the recall page and you will be able to see if it applies to your rv refrigerator. Hope this helps!!!
Sep 14, 2010 | Dometic RM2652 Refrigerator
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Dometic 2652 recall repair and now converter heats
you will need to get an adaptor for your plug as the electric volts in mexico are different than US.You can go to hardware store and they will tell you wich one
Apr 11, 2010 | Dometic RM2652 Refrigerator
Refrigerators Logo
1,378 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
