Question about Microsoft Office Professional 2007 Full Version for PC
Wizard unable to create form
I'm using Access 2003. I have a relationship set up and I want to create a new form in form wizard using the two related tables. I've created this form before in the past and it has worked. But it is not working this time. My students and I are getting the error message "wizard unable to create form". What's the problem?
  • cody-m901 Nov 10, 2008
    The relationship works
  • Anonymous Dec 01, 2008
    I have the same problem and it has nothign to do with relationships because I am using jsut one table
I had this problem and it was because a computer class was installing multiple kinds of access on one computer. they wanted to teach all of them, but are now screwing them all up. ha.
Posted on Aug 05, 2010
    New Friend:
  • 144 Answers
Check the relationships for errors.
Posted on Nov 10, 2008
Can u plz mail me tha easiest way to use Ms Access, like Creating relationship, with the table, creating form, query etc.
In general you initiate this process by pressing the "Relationships" button on the MS Access toolbar. It is the button with three small boxes arranged in a triangle shape.
When it first comes up it will give you the option to add tables. You can add any set of tables including the possibility of adding one table more than once (you would do this if you wanted to create a relationship between fields in the same table).
Once you see the tables you're interested in, you simply drag the field from one table over a field in another table. The fields should be those that will define the relationship. Once done, you should see an Edit Relationships window. You can get back to the Edit Relationships window later by double clicking the line in the relationships window.
MS Access does a good job of figuring out the relationship type. For example, if you match a field in one table, that is not a key, with a primary key in another table, Access will make this a Many-to-One relationship.
This can become a very deep subject. Hope this at least gets you in the right direction.
Dec 18, 2010 | Microsoft Computers & Internet
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
Unable to crate dial-up connection
Why not try to create in the INTERNET OPTIONS under Control Panel. Click connection then hit ADD then set the settings. Try to set also its settings on LAN SETTINGS. Then whenever you try to connect to dial internet use the connection you created in internet options.
Sometimes you can get to Dial up connection one from the regular creation and one from the Internet options. If this could be the case.
If you still not able to connect to internet even with the right settings. Chances are, you have virus in your system. Could be Trojan vundo.
May 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Apr 09, 2009 | Microsoft Computers & Internet
No available fields in form wizard
If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
Feb 10, 2009 | Microsoft Office Professional 2007 Full...
Nothing happens when I click form wizard?????
You might cancel the security wizards option during your 1st time click of "Form Wizards" of More Forms menu. To solve this problem follow this steps.
  1. In Access 2007, click the Microsoft Office Button, and then click Access Options (the office 2007 logo on your left top area of access 2007 or the Circle button on your top)
  2. Click Trust Center.
  3. Click Trust Center Settings.
  4. Click Trusted Locations.
  5. Click Add new location.
  6. In the Microsoft Office Trusted Location dialog box then click Browse.
  7. In the Browse dialog box, locate and select the folder that contains the Access database, and then click OK.
Nov 18, 2008 | Microsoft Office Professional 2007 Full...
Access 2007 forms wizard
If you run a repair install of office 2003
Jun 04, 2008 | Microsoft Office Professional 2007 Full...
How we can create Forms & queries in access
For forms, open a data table in view mode, while there locate the forms setup wizard. For your first try just answer the questions the best you can for the wizard. When there are no more questions to answer wizard will create a form for you. From what you learn doing that you may get enough hints to make a form from scratch. Just keep in mind you always build a form from the fields in a table.
Now for the Query, start out the same way and use the wizard. Query to most folks means ask a question and get an answer. In access query is a way to present sub sets of data or ways to modify data in the fields of your tables.
Jun 03, 2008 | Microsoft Computers & Internet
Copying Microsoft Word macros to new computer system
Macros are stored in one of two places, Irene - and you decide where and when you create one. When you select Tools -> Macro -> Record New Macro you’re prompted to either create the macro in the global template (normal.dot) file, or the document you’re currently working on - by default, normal.dot is selected so that the macros are available in all documents you create.
Your normal.dot file is also where all custom styles, toolbars and autotext entries are stored, and it’s possible to transfer all of these - plus your macros - from one machine to another courtesy of Word’s Macro Organizer tool. The walkthrough below explains how to access it and back up your macros to a file you then transfer to your second PC before copying those macros into the normal.dot file on that computer so the macros are accessible from there too.
While this tool is the best way to transfer macros, or other individual elements of your normal.dot file (just select the appropriate tab to transfer styles, toolbars and autotext entries in exactly the same way), if you’re migrating to another PC you may wish to take all your settings with you. If you have Office 2000 or later you can use the Save My Settings Wizard to back up all your Office customisations - including the normal.dot template - and then use the same wizard on your new computer to restore them to the version of Office installed there.
Office XP and 2003 users will find the tool installed with Office -access it from the Microsoft Office Tools menu on the Start -> All Programs menu; Office 2000 users need to download it from here. It’s called the Microsoft Office 2000 Profile Wizard here.
Nov 03, 2007 | Compaq Presario 5000 PC Desktop
Microsoft Office Professional 2007 Full Version for PC Logo
1,708 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
