Question about Jensen BP212 Car Subwoofer
Repair of speakers inside Jensen BP212
Hello, my son just bought a bp212 for his 02 Civic. Unfortunately, after the install we found out that one of the speaker tabs of the first speaker is broken off at the wire and the tabs are pointed in a direction that we can't get to unless we remove the speaker....So my question is what tool do we need to remove the plexiglass from the front of the sub box to access the speaker?
I just got a bp212, and the reason for it is different, but i also had to remove the plexiglass front, i just used a hex bit, and unscrewed them.
Posted on Sep 02, 2010
I purchased a used Jensen UV10 from a friend and installed it in a 97 eclipse spyder. I recently bought a 2003 chevy silverado 1500hd LX, and took out the aftermarket JVC cd player to install my Jensen....
Depending on the model, the Silverado may have an amplifier between the OEM radio and the speakers. If that is the case, you will have to remove it and wire directly to the speakers. Check the wiring schematics for the original truck radio option (one source is
Jul 16, 2017 | Cars & Trucks
Have a Jensen speaker and cover damaged. need to replace. Tell me where
The cover can be mended with good tinkering , use a soft platform and a soft hammer to trim the shape and then if the paint has gone it can be touched .
however is the cover is damaged beyond repair then the only option is the Jensen store unless you re able to source from a scrapped one... check car stereo installation centers.
Sep 14, 2011 | Jensen Car Audio & Video
Okay i have a jensen bp212 car subwoofer but the lights dont com on what should i do
my only question, though stupid, would be, did you plug the light wires into the stereo deck?
info for light hookup on page 3 of manual, if you don't have the manual, here it is.
Aug 27, 2010 | Jensen BP212 Car Subwoofer
Just bought jensen uv8 touch screen and installed speaker wires will produce no sound except for sub input on rca please help?
it could be a case while you or someone installing the unit could or might have blown out the speaker output of the unit
try taking the unit out connect the red(acc wire) yellow(constant wire) together connect the black(ground wire)
get a test speaker and see if u get sounds
Jan 26, 2010 | Jensen VM9510 Car DVD Player
Jensen vm9413 no audio ouput
i thought my banswer went through but i guess not so i'll do so again.Often a defective speaker can cause this problem.So before you decide to replace the unit or repair it,when this happens again disconnect one speaker at a time and see if it doesn't come back on after connecting a specific speaker and goes off if you reconnect it.If it does you've found your problem.But sometimes a speaker doesn't melfunction until put under a strain.So you can also check by seeing if it shuts down at higher volumes and plays longer at low volumes which will tell you also that it is an external not internal propblem.Let me know what happens after the speaker test
Oct 11, 2009 | Jensen Car Audio & Video
Jensen VM9312 Installation
Are you saying you need a replacement face plate for this model ?
Jul 13, 2009 | Car Audio & Video
Subs not hitting
remote wire turning on amplifier?
Ground for amplifier?
Gain improperly set?
Radio output crossed over above tuning freq. of enclosure?
Just suggestions. Not much info to go by.
Dec 15, 2008 | Jensen BP212 Car Subwoofer
low power needs adequate ground
Aug 17, 2007 | Jensen BP212 Car Subwoofer
Battery problem
I would recommend increasing your altinator and getting a yellow top battery. Basically what is happening is your using more power than the car can produce.
Dec 20, 2006 | Jensen BP212 Car Subwoofer
Car Audio & Video Logo
117 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
