Polti is heating up ok but when you connect hose for steam and press handle no steam results
  • 2 more comments
  • joreill Nov 10, 2008
    The steam is generating as the Iron attachment works ok,
    Dont understand what is meant by the steam holes are "stucked" if it means blocked they are not as far as I can see.
    The cleaning hose attachment just is not producing the steam.
    The Model is Polti Vapoetta 2400.
    Polti is heating up and the light comes on to say steamm is ready but no steam getting through to cleaning attachment.
    model is Polti Vaporetto 2400 and how do I check the switch on the handle
  • joreill Nov 18, 2008
    Now established Switch on Hose attaschment is broken so need new hose attachment
    where can I buy parts for this PoLTI Vaporetta 2400.
    Sean
    Sergeant:
    Novelist:
  • 196 Answers
Ijust disconnect the hose. there is a small hole where the hose connects.
 put there a litlle screwdriver in few times in and out. and then the steam will be proper.
the polti must be switched on and heated up before you de this.
be carefull, when you put the screwdriver in, the steam can come on your hands and face.sp please take care.
Posted on Nov 10, 2008
    Genius:
  • 1,239 Answers
Hi This control panel switch regulates the temperature of the water in the tub. It also plays a role in controlling the fill cycle. If you suspect this switch is faulty, remove it and take it to a professional service person for testing (the test takes special equipment). Or, hook a test wire across the switch terminals; if water flows, the switch is faulty. If the switch is faulty, replace it with a new one of the same type. Connect the new switch the same way the old one was connected.
If there's a problem with both water temperature and tub filling cycles, both the temperature switch and the timer may be faulty. Test both components and replace them as necessary. Procedures for testing the timer can be found below.
  • ABHISHEK.C
    ABHISHEK.C Nov 10, 2008
    hi
    The heating element is used to help dry the dishes. In most dishwashers, the heating element fits around the screen in the bottom of the tub housing; it looks like an electric oven element. The heating element doesn't malfunction often, but it can burn out. If you suspect a faulty element:
    Step 1: Test it with a VOM set to the RX1 scale. Remove the dishwasher's bottom access panel and disconnect one of the power leads to the element. Clip one probe of the VOM to each element terminal. If the meter reads between 15 and 30 ohms, the element is working. If the reading is higher than 30 ohms, the element is faulty and should be replaced.
    Step 2: As needed, replace the heating element with a new one made for the dishwasher. Disconnect the electrical leads to the element's terminal screws and remove the nuts or other fasteners that hold the element to the terminals. From inside the tub, lift the element out. It may be held by clips and ceramic blocks in the tub, but you can easily thread it past these spacers. Set the new heating element in position, reconnect the power leads, and replace the fasteners that hold the element in place.
    Sergeant:
  • 306 Answers
May be the problem wud be a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so get a piece of wire ong enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone.. then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future...
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
may i know the exact model of your unit.
make sure that the switch on the handle was properly working right./
    Brigadier General:
  • 6,966 Answers
Without a specific model number, any assistance provided would be generic in nature. In most steam systems and based on your description, probable general area to start checking would be:
  • rubber seals that serves as gaskets. There is probable pressure leak;
  • faulty valve;
  • clogged/blocked lines/tubings, pipes/hoses;
  • thermostat faulty, cutting out early, boiling temperature barely or not even reached;
  • relief valve locked in open position.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 18, 2008
    For replacement parts for the Polti Vaporetto 2400 Steam Cleanerm pls start by clicking here or here.
  • Louie  Role
    Louie Role Nov 23, 2008
    Hi again,
    Any developments or updates so far?
  • 849 Answers
Check the steam is generating or not, otherwise the steam hole are stucked.
HOSE LEAKING WHEN USING TOOLS OTHER OSE STUTTERING AND WON'T STEAM HAVE USED KALSTOP
on further inspection the hose that is leaking appears to have a big 2 cm short faill like its been pushed into itslef thats hwy its leaking its not connecting correctly and the other hose i think a spring may have gone on the trigger itself. as when press steam come out and then won't its like the button you press to swith it off is shyt off and no steam.
Nov 20, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Handle is to hot to hold and steam is comming out of the top of the handle
i believe your hot water/steam hose/tube runs through the middle of
the handle down to the floor(where it sprays hot water/steam. it ether came apart on the inside or you have a hole in it.
Sep 02, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
Steam cleaner not creating steam
Sorry this wont get resolved in this area, this is the Computer section. Please repost this in the correct location.
Thanks,
Armymason
Feb 26, 2009 | Computers & Internet
Polti spare parts
i have a 950 and it does not heat up any more . the red light comes on but thats it
Feb 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam polti 2001r, heats up clicks, but no steam!!!!!!
the solenoid valve isn,t operating when you pull the trigger. It is caused by either the coil has burnt out on the solenoid or the valve itself is stuck
Nov 06, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Have a polti vaporetto 2400 been used 3 times approx but out of warranty heats up ok but wont release steam when trigger pressed.have tried flushing water in tank with no results
these machines like to be used regularly. if allowed to sit (especially after using tap water) they may buld up lime deposits on valves and cause them to stick. you could try filling with vinegar and let set, also tilt it so vinegar runs into valve area. you could heat the vinegar and it will run through the trigger valve area. if this doesn't work you'll need to replace trigger valve.
Jim
Jul 25, 2008 | Vacuums
Polti 1500 no steam just droplets of water
Before trying anything else make sure you turn up the pressure control knob in the direction of the + sign if it is turned right down you will have steam in the system and the gun will be heard to click open the flow control valve but you will not get any steam because the control screw is set too low just turn it anti-clockwise to increase the flow and your good to go .I hope this helps I have one too and I some times forget to turn up the flow and wonder why for 3 minutes then realise that during storage and manuevering it gets turned down by accident and i turn it up and all is well again.
Jun 20, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
