Question about Panasonic TH-42PW6BX 42 in. Plasma Television
Hooking up my plasma to a Panasonic digital tuner & dvd player
I have recently bought (today) a Panasonic DVD Recorder Model No. DR-EX75 to replace my standard panasonic digi box - I had no dvd player. I simply took the scart cable from the back of the digi box and plugged it into the appropriate scart socket on the new dvd recorder and likewise the aerial socket and additionally dealt with the mains power supply. I cannot get a proper signal. I only receive a picture in black and white which flickers constantly - I have tried changing all the input options on my screen none of which seem to make any difference. Please bear in mind additionally that the panasonic is a monitor only and does not receive a television signal. I'd appreciate anyones help before I take it back to the shop. Many thanks
SOURCE:
techman
  • 3130 Answers
SOURCE: SCART SOCKET SCROLLING PICTURE
Its probably a bad cable otr the connections inside the set where the scket connects to the chassis has broken connections on the mounting. To fix this your gonna need to know how to solder and know the HI Voltage issues with tv sets so if you dont please seek a pro to assist you with this repair. Good Luck
Posted on Jun 26, 2006
  • 3 Answers
SOURCE: panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Posted on Sep 27, 2008
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
  • 7 Answers
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Posted on Oct 03, 2008
SOURCE: Panasonic DVD Player only plays in black and white
have you tried swapping the scart lead socket on the back of the dvd vcr i had this problem and i found out i was using the wrong scart socket make sure you are using the t v scart and not the
decoder one
cheers
Posted on Dec 14, 2008
Does the JVC DR-MV5S DVD recorder/VCR combo unit have an analog tuner or digital tuner, so that you can record one channel while watching a different channel on your TV?
You can read what JVC is telling about the recorder. It is not an digital tuner, but still you can record a DVD and watch another channel or vice versa.
Want to read the whole manual? click the link:
DVD Recorder Hi Fi VHS Combination DR MV5S Introduction
Jul 25, 2014 | JVC DR-MV5S DVD Recorder/VCR
The DVD player on my Panasonic DVD DMR-EX75 is not working. It no longer is able to read the DVD disk. Is it worth repairing or replacing the DVD drive? The system also has a large Hard Drive which still...
It is up to you, if you are able to obtain a replacement DVD drive for this model series, and it isn't too expensive, go ahead. There may be tips on installing the DVD deck on other forums - or it might be really simple (a DIY job) - or for extra labour costs, a qualified technician can fit it for you in a service centre.
So the short answer is YES it is worth repairing since the HDD is still functioning - if you are concerned about that as well as the DVD drive, get the whole unit assessed by a workshop; they can advise you further.
A second opinion always helps in a case like this, but I would recommend trying to obtain a replacement DVD drive for this model, either locally or by ordering online. This one IS fixable.
May 28, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Dec 09, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Time change
I pressed all the buttons on the remote control untill I found the right ones. It was trial and error.
Apr 01, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Remote interacting with TV
According to my manual the codes for Samsung TVs are 31, 32 or 43.
Press and hold the TV on and off switch button.
Enter the two-digit code for your television set (while holding the TV power on the remote)
Nov 11, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic TH-42PW6BX 42 in. Plasma Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
