Question about GE 31GT660 TV
GE TV picture closed in went back to full size then went blank no sound. squealing sound heard 31gt660 S# 943422808 C# CTC187CH
  • davebruce Nov 10, 2008
    31gt660
    S# 943422808
    C# CTC187CH would like instructions on a repair can I get more info from this person. Solution #1posted on Oct 25, 2007
    Guest
    Rank: Apprentice
    Rating: 0%, 0 votes
    horizontal output transistor is defective,also change out damper diode(cc4402). very common repair. use buh517 transistor. they last longer. i just repaired my own personal set. same problem. Solution #1posted on Oct 25, 2007
    Guest
    Rank: Apprentice
    Rating: 0%, 0 votes
  • davebruce Nov 14, 2008
    while watching tv picture closed in the went back to full size then closed in an went black no sound other then squeal sound
    davebruce
  • 4,234 Answers
I'm sorry about the nonsense solutions that you have received thus far. Since the set "recovers" somewhat, this can be a couple of things. Most simply, it can be a poor solder joint that is interrupting normal operation. This is easily fixed by resoldering any connections that appear to be grainy or have rings. Please unplug the set and let it sit for a while before attempting this. Note that TVs retain quite a bit of electricity and can be dangerous even when unplugged.
That being said, the breakdown of the internal insulation in the flyback transformer can cause this as well. If you can solder, look for the poor connections first and update this if you still have problems.
Dan
Posted on Nov 14, 2008
  • 734 Answers
There is no way out other then you call a technician...
    Genius:
  • 1,239 Answers
Hi after removing screws on back you will find 2 tuners the left tuner is fine tune adjustment by adjusting it your problem will be solved please rate it.....thank u
Posted on Nov 10, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
The first thing you should try is a hard reset. Unplug the tv before going to bedthen plug it back in in the morning. If this doesn't work you have anessential failure which will need repair. The two main causes of thetype of problem you are having is either a poor solder connection righton the board where the screens connectsto the TV, or the second a faulty Picture tube. I think the picture tube has problem. This will huge cost to repair. Check out with warranty. Either way it will need tobe attended to by a technician. I recommend checking the warrantyinformation that came with the unit to see if there is any way you canrecoup some or all of the cost of a repair which will be needed.Hopefully the manufacturer will take care of it for you if it is withintheir timeframe. I hope this helps...
thanks
good luck
    Sergeant:
  • 306 Answers
Squeal sound  is due to an excessive load on the power supply, check the horizontal output and flyback transformer.Moreover horizontal output transistor is defective,also change out damper diode(cc4402).  use buh517 transistor. they last longer. and if it does not turn on replace eeprom ic.
  • AbdulRahiman S Nov 10, 2008
     take a look at the horz. driver and the driver transformer.
  • 849 Answers
It need to repair ecnically by qualified technician.
Tv went blank and started making a clicking noise
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 01, 2014 | Proscan PLED4274A 42" LED TV 1920x1080, 60...
I own a GE 31gt740 and I heard a squealing noise a few times, but TV still worked. Then, I turned it on one day, heard the squealing noise, then saw a little smoke, some crackling, and no sound or picture....
I think that the problem of your tv is the flyback transformer. The noise you are hearing is the high voltage, it is leaking from the flyback transformer. The smoke you see may came from the flyback or the capacitor. To be sure to the problem, try to remove the back cover of your tv but be sure to unplug it. Try to plug it, then turn on your tv but you should turn of the light so you could see the high voltage that is leaking but be very careful when doing it.
Jun 21, 2011 | GE 31GT740 31" TV
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Heard a click picture went blank turned off and back on heard a high pitch hum
SOUNDS LIKE A HIGH VOLTAGE LEAK. MOST LIKELY SOME CAPACTIORS AND YOUR HORIZONTAL OUTPUT TRANSISTOR OR (HOT)
Feb 20, 2010 | RCA HD52W58 52" TV
Picture started getting fuzzy then it went out
yes,remove the back of the tv,on the power board you will see the problem.replace those capacitors on the power board.this will allow the set to work.the black bars may still be there.this is an indication of a bad panel.
Aug 08, 2009 | Televison & Video
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
Picture too wide for screen
your problem is called blooming as you might be aware of very high voltage in tv. you can check 1 high output voltage fron power supply. 2 if it is ok then the problem is in horizontal section.you can check cap.in hor. section at last flyback transformer. hope this will help.
Sep 25, 2007 | GE 31GT659 31" TV
Squeals Like a Pig
REPLACE HORZ OUT TRANSFORMER
Nov 06, 2006 | GE 31GT740 31" TV
GE 31GT660 TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
