Question about Steam Fast SP-660 Iron with Auto Shut-off
Steam Press sp-660 will not steam with distilled water
The steamer will turn on and will not steam with distilled water. My husband believes the "water pump" probably does not work. Where can I get parts?
  • Anonymous May 17, 2009
    My 660 worked beautifully with distilled water up until today. Now there is no response when I press the steam button. ????? Also the temp and steam lights don't work even though the table is hot hot hot. Has anyone made contact with the Steamfast brand SP-660 steam press
    contact Top Innovations
    1-800-711-6617 Number? They're only M-F, 8-5 central time
    Problem Solver:
  • 3 Answers
My Steam Press (SP-660) the Mercury switch went out. An electrician looked at it to find out the problem. The question is now, how to get a mercury switch since most hardware stores do not carry them any more. Due to certain state regulations.
Posted on Nov 29, 2010
My press has the same problem. Everything works but the steam. I took it apart and found the circuit board has scorch marks. Now I'm looking for a replacement board PCB:DTJ120
Posted on Aug 12, 2009
1-800-711-6617
Posted on Dec 09, 2008
2 Suggested Answers
SOURCE: Steam Fast SP-660 Iron will not steam with distilled water.
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can't I...
Believe it or not, distilled water is quite corrosive, more so when hot. Distilled water doesn't contain any dissolved ions but the water is ionic in nature, the ions of every water molecule tend to dissolve away other elements. Steam generating plants and steam ships as well as steam heating systems treat the water with chemicals to keep the water from eating away the metals of the system and test the chemical makeup several times a day while operating. [I spent 4 years in the Navy on a steam powered ship.]
The same holds true for smaller steam appliances like espresso machines and steamers. A very thin coating of calcium carbonate [limestone] is a good protector but too much makes for inefficiencies and burned up elements.
Somewhere I read that Chrystal Geyser spring water is approximately the correct ion balance for espresso machines and I have been using it for years in my espresso machine. In any case you still need to occasionally de-scale your steamer per the manufacturers recommendations.
Feb 03, 2015 | Rowenta Irons
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    My steam iron will not steam. How do I clean it?
    Mix (1 to 5 parts) white vinegar in distilled water and pour into the reservoir. Let sit for an hour or so, then pour out through a coffee filter into a container, then pour back into the iron for another hour. At this point, heat the iron and try the steamer function. The vinegar solution will clean deposits from the steam jets, so don't try to iron anything yet. Keep running solution through until sputtering stops. Wash out the reservoir with distilled water, then refill and steam wash the ports several times to remove the vinegar. If you can get it clean, continue to use only distilled water in the iron.
    Sep 07, 2009 | Irons
    Worn out pad
    I order my replacement press cover pads online at "Sew4Less" - silicone covered pad - they sell for $12.95 /ea plus $5.00 shipping (measures 24"X9") and fits my Steam Press SP660 perfectly.
    Apr 19, 2009 | Steam Fast SP-660 Iron with Auto Shut-off
    How can I prevent my iron from leaving white residue on clothes?
    white residue is caused by lime in your tap water.perfectly safe to drink,but when boiled [as in making steam] the lime is left behind. over timeit builds up in the 'tank' buy a gallon of distilled water from the grocerery-about $1 mix water with white vinegar,50/50 and 'steam it out' once or twice to remove deposits in the resevior.steam it out again w/pure distilled water.try it out on your husbands clothes before you iron your delicates again!!
    Dec 22, 2008 | Panasonic NI-R73NR Iron
    Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
    Steam Question
    Found the answer. The steam button is built into the handle. Push the button and you have steam.
    Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
    Rowenta DA75 - Won't Steam
    Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
    Thanks J
    Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
    Steam Fast SP-660 Iron with Auto Shut-off Logo
    807 people viewed this question
    Top Steam Fast Irons Experts
    Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
