Question about Kenmore 94702 Front Load Stacked Washer / Dryer
My dryer stopped working -- won't turn and motor makes odd noise like not engaged properly
Dryer motor will run and sounds like the dryer motor is running but the "belt" may be broken because the dryer cage does not turn. What should I do? BK
  • Wence Dec 01, 2007
    Kenmore dryer cage will not turn, the heat is on.
  • p_nut33 Apr 05, 2009
    Can anybody send me a picture of the belt tensioner/motor assembly. I can't figure out how to get the tensioner to pull opposite to the motor spindle. p_nut33@hotmail.com. The spring attaches to the lower part of the tensioner arm but this just creates no tension whatsoever.
At the rear of the unit on the lower right hand side of the dryer you will find a 6" X 6" vented panel. If you remove it you will have access to the Dryer motor and belt. Check to see if the belt has derailed or broken and you can also check to see if motor is operational.
Posted on May 24, 2007
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Still turns after opening door
When the door is closed the switch will close, allowing power to circulate through the rest of the circuit. When the dryer door is open the switch will open, breaking electrical contact to the neutral connection of the circuit and stopping the flow of electricity. so it sounds like a bad dryer door switch.
Feb 02, 2012 | Frigidaire Dryers
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
My whirlpool dryer WED5800SW0 won't start. It is receiving power because the timer switch still makes the clicking sound before you start the dryer. I have had recent issues of the pin not engaging...
heatman101
Aug 11, 2011 | Dryers
My electric GE dryer stopped working today, when
sounds like the motor is running, the belt could likely be broken and be the culprit, this is if the motor is turning for sure after you start the dryer
Sep 30, 2009 | GE Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer motor has trouble starting
sounds like you are having or go to have a motor problem repl/ motor
Dec 29, 2008 | Dryers
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
go to back of dryer should be a panel on back of the drier pull it off and check the belt
Dec 29, 2007 | Maytag LSE7806A Top Load Stacked...
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
251 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
