Question about Dell Latitude D600 Notebook
MY LAPTOP BATTERY DOES FAST CHARING
WHEN I CHARGE MY BATTERY , IT CHARGES FULL IN 15MINUTES.AND THE BATTERY DROPS AT A FAST RATE. WHAT IS THE CAUSE OF THE PROBLEM. IS IT THE CHARGER THAT IS NOT GOOD OR THE BATTERY.
    President:
  • Dell Master
  • 1,314 Answers
Your battery is bad. Replace your battery and that will solve the problem.
Thanks and please take a moment to rate as fixya.
Posted on Nov 10, 2008
Pls wat Can overchargin cause to a laptop,cause i hav a problem i think was cause by overcharging my zinox laptop for about 11 hours.
Continuous over charging can shorten the life of the battery.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 12, 2013 | Computers & Internet
Laptop works great on AC input, Battery charges and discharges per the indicators but will not power up on DC only. What needs replacing?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 03, 2013 | Fujitsu LifeBook S6231 Notebook
Acer timelinex 5830t laptop batterij
Nov 30, 2012 | Computers & Internet
Gateway battery only charges to 70 %
Sep 03, 2012 | Gateway Computers & Internet
Battery not charing
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | AT&T Computers & Internet
My Kodak m1093 stops charing in 5 minutes on a new battery. The old battery was dropped due to i thinked it goes dead but that was an lens error that i fixed later. when i used a new branded battery, it...
Hello, try putting in more expensive re chargeables. And if that doesnt work, get yourself a discharger. This machine discharges the batteries safely and allows them to fully charge to their full potential. There are more stronger batteries coming out every week, just try a couple and see how you go. Also have you tried using a different charger? Perhaps the charger may not be 100% all of these things make a difference. I hope I have helped you.
Mar 28, 2011 | Kodak EasyShare M1093 IS Digital Camera
Just put new regulator on charging system. It charges but not enough. it jumps from 12 up to 12.4 or so but for one theres a loose black wire at front of engine that runs in the loom with the alt wires....
You may be OK at 12.4. You should check the charge output with ALL lights and accessories turned on. If the battery is fully charged you won't see 14+ v charge rate. It drops off to almost battery voltage when the battery is fully charged. Does the battery run down over a period of hours or days? Or stay charged? There isn't much that will cause a reduced charge rate. Regulator, bad ground(s), defective stator/rotor assembly, dirty battery terminals. Black is usually a ground wire. You might want to check and see where it went.
Mar 21, 2010 | 2001 Harley Davidson XL 1200 C Sportster...
Battery will not fully charge. It currently only charges to 96%
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, ie. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Feb 12, 2010 | Acer Aspire 5002WLMi Notebook
Acer aspire 3050 new battey will not charge
Sometimes batteries need a full 24 hr initial charge before they will work. You would be advised not to use the M/C during this period. Also it will take several charges before the battery reaches it's optimal performance.
This could be the problem so it's worth a try.
Aug 21, 2009 | Acer Computers & Internet
Slow or fast charge
Yes, the amperage your charging at determines charging time. The higher the amperage, the faster it charges. Your battery is rated in mAh or milliamp hours. One Ah means the electric charge transferred by a steady current of one ampere for one hour. A mAh would be 1/1000th of an amp for one hour. If your battery is a 1500mAh battery it means 1.5 amps for one hour. This charge current should not exceed the rating of the battery. It would cause possible excessive heating and possible a fire or explosion, especially on newer more volatile batteries like lithium polymer batteries. The life of the battery charge when fully charged will be similar no matter how you charged it, but slower, lower amperage charges will maintain your battery better than quicker, higher amperage charges and help extend it's life to its potential.
Dec 11, 2006 | HP iPAQ RX3715 Pocket PC
Dell Latitude D600 Notebook Logo
90 people viewed this question
Alun Cox
