Need these ports open but even after adding TCP and UDP exceptions they are closed. Firewall is wide open with no filtering for now. Server 2003 Ent. SP2 with all latest updates 20 Closed ftp-data 443 Closed https 873 Closed rsync 3306 Closed mysql 5432 Closed postgresql 10125 Closed SOAP
  • 3 Answers
More information is probably needed before you can solve this problem. More likely than not, you have an anti-virus and/or spam filter. You need to double check these programs to assure that their integrated firewalls are not activated. If you need further assistance, I would suggest adding another post and including information on any anti-virus programs, spam filters and also describe the routing scenario you have (i.e. are you on the same network/subnet, have multiple routers, etc.).
Posted on Nov 10, 2008
Fuji xerox DC-II 3005 have 027-516 error, how to solve?
[Cause] During the transfer using SMB of the scan to PC
feature, the SMB server could not be found.
[Remedy] Take one of the following actions, and try again:
Check the following to see if the destination SMB server
and the machine are set up properly for network
communications:
- Check the network cables are plugged in securely.
- Check the TCP/IP settings.
- Check communications of port 137 (UDP), port 138
(UDP), port 139 (TCP).
Check the following to see if the computer correctly
works as an SMB server.
- Check if the file sharing service for Microsoft
Network is activated.
- Check if [NetBIOS over TCP/IP] for TCP/IP
is activated.
- Check if the file sharing service (using
communication through port 137 (UDP), port 138
(UDP), and port 139 (TCP)) are authorized for the
Firewall settings.
For communications which exceed the subnet, check the
WINS server settings, and check if the server address
can be resolved correctly.
For Windows NT 4.0 Server/Workstation, use the
following steps to see if the NetBIOS interface device is
activated on the destination SMB server:
1. Select [Start] > [Settings] > [Control Panel].
2. Display [Services], then select [Messenger] service.
3. Select [Startup] > [Auto] > [OK], then select [Close].
4. Select [Devices] in the [Control Panel], then select
[NetBIOS Interface].
5. Select [Startup] > [Auto] or [Manual] > [OK], then select
[Close].
6. Reboot the
Oct 11, 2016 | Xerox Office Equipment & Supplies
WHAT ARE THE PORT RANGES FOR ADDRESSES
Usable tcp and udp ports range from 1 to 65535. However you should not need to open any ports by default. Most routers include a stateful packet inspection (SPI) firewall. This is a fancy way of saying the router inspects the packet on it's way out to the internet when a computer on the inside of the firewall sends it out to the internet. The firewall will only allow connections from the internet on that TCP or UDP port if it returns from the original destination. For example, if you send a packet requesting the web page at cisco.com, the firewall will only allow traffic back into your network on TCP port 80 from the web server at cisco.com. If a packet from any other IP address tries to piggyback into your network through tcp port 80, the firewall will block it.
The only reason to open ports on your firewall is to allow a server inside your network to receive unsolicited traffic e.g. a web server inside your network may need TCP port 80 and 443 (HTTP and HTTPS) opened if you want to be able to access it from the internet. A mail server may need port 25 and 110 open for SMTP/POP e-mail. However, most home users do not host their own mail or web servers.
Mar 22, 2014 | Cisco Linksys Refurbished E3000...
Error 1005
1. This is a generic error that describes that phone is not able to find the PC. There can be many reason for this
2. Try restarting PC Remote Server
3. Make sure that battery saver mode is not turned-on as phone networking is stopped when battery is low.
4. Try restarting your PC and restart PC Remote Server
5. Do you have any firewall or anti malware installed on your PC? These softwares might be blocking the connection with PC Remote Server. During server setup, a rule/exception is added to Windows Firewall to enable incoming connection from Phone. If your security software is not querying Windows Firewall for exceptions, then you need to manually add a new exception to allow incoming TCP and UDP connections on local port 61314. Try connecting after stopping security software.
Please add the rules to allow incomming and outgoing connections for PC Remote Server at port 61314.
May 03, 2013 | Computers & Internet
Cannot connect server ...... client PC diplay this message
Can you PING the L230 device from the server? In other words, are you confident there is a clear IP path from server to device? Also, if you're running on XP, turn off the XP firewall as a test. If that works and you still want to run with the firewall on, then you'll need to specify specific ports to be opened up on your firewall or your domain's firewall policy. Those ports, as listed from NComputing's website are:
Port Exceptions
  • For L-series device connection
    • TCP: 27605, 27615, 3581, 3597, 3645, 3646
    • UDP: 1027, 1283, 3581
  • For vSpace registration
    • TCP Port 3630
    • Point to:
      • register.ncomputing.com
      • or 85.214.107.229
  • For vSpace Update
    • TCP Ports 20 & 21
    • Point to:
      • 70.182.176.102
      • or 81.169.173.128
      • or 81.169.173.128
Jun 12, 2011 | NComputing L230 Network Terminal
My nat is strict
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
TOM
Jan 26, 2011 | Computers & Internet
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 05, 2011 | NetGear DGN2000 Wireless Router
Can I change the Nat type? Can't figure out how to change it from type 3?
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My Netgear PS121 print server requires disabled firewall (Win XP) to install. After installation, which ports has to be open in Windows Firewall, if I want the printserver to work with Windows XP Firewall...
You may try to set Exceptions on the XP Firewall configuration.
Open Windows Firewall, go to Exceptions tab.
Make sure that File and Printer Sharing is checked.
Then click Add Port.
For Port Number, enter 139 and select TCP.
Do the same for port 445 TCP, 137 UDP, 138 UDP, and 9200 TCP.
Nov 03, 2009 | NetGear PS121 Print Server
No incoming and outgoing call
You may be behind a firewall or NAT. You can set an option that you are; if that still does not work, you may need to open some ports on the firewall.
Yahoo! Messenger uses a variety of ports.
Service Ports Chat & Messenger TCP Port 5050: Client Access only Insider/Room Lists TCP Port 80: Client Access only File Transfer TCP Port 80: Server Access.
Your ISP may block this port, as its used for web hosting.
You can change port in Messenger, Preferences, File Transfer. Voice Chat UDP 5000-5010
TCP 5000-5001: Client Access
If UDP Fails, TCP will be used instead, see below. WebCam TCP Port 5100: Client Access Super Webcam TCP Port 5100: Server Access P2P Instant Messages TCP Port 5101: Server Access
PMs between Buddys may not use the Yahoo! Server, but this is not a requirement.
Feb 03, 2009 | Yahoo Messenger
TEW-452BRP - can't open a port (forward)
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Feb 23, 2008 | Trendware TEW-452BRP Wireless Router...
Computers & Internet Logo
67 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
