Question about Olympia OL2410 Cordless Phone
LCD Display shows only a line of squares across the middle of the screen
All of a sudden I can see only a line of [][][][][][][][][] like that across the middle of the LCD screen and if I hold the telephone at an angle I can see the name of the person who is calling but not the telephone number. I can no longer tell what time my missed calls were received it is blank above and below the middle of the screen. I unplugged the telephone and that did not work I was not able to remove the battery but the phone works apart from that I am able to make and receive calls it's just the LCD that's no longer working and I haven't had the telephone more than 2 weeks yet!
4 Suggested Answers
SOURCE:
SOURCE: phone is not working
It is not worth to fix it.  I just got a new one.  Thanks!
Posted on Aug 08, 2008
SOURCE: Olympic InfoGlove Blue
How do you reset this id caller?
Posted on Jan 03, 2009
guru_fixya
  • 944 Answers
SOURCE: My globe will no longer
Your unit has some settings problem.You have to reset the unit.Try resetting the unit.If still the problem persist you have to reset the infoGlobe.txt file using PC interface cable.Which they will do in service centre only.
http://www.lima.com.tr/BasicTiger/Applications/PDF/appn_071e_The%20magic%20globe.PDF
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 10, 2011
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
46 in Samsung TV. . it started with horizontal lines going across the screen, just a few then in a short time the lines fill the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 23, 2015 | Samsung LN46A650 46 in. LCD HDTV
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 17, 2014 | Sanyo Televison & Video
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
My sony bravia 32" is
hi ;
there's a problem in screen driver of your LCD, if you lost your receipt,that's bad luck.
if you know how to disassemble the back case of the TV , you can try some RESETTING of connectors from LCD screen driver to display driver board
its only 50% chance to remove the line.
thanks.....
Sep 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
Olympia OL2410 Cordless Phone Logo
48 people viewed this question
Top Olympia Lands Phones Experts
ray gallant
ray gallant
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
