After dropping some salsa dip on my keyboard,the letters g,h,@,x,c,v,m,,,.,/,don't work anymore.
    President:
  • 1,314 Answers
You'll need to replace your keyboard. Alternatively, you can try rinsing your keyboard out in distilled water and letting it dry for 72 hours before using it, but since keyboards are only $5, it's not really worth the hassle unless you have one of those very expensive ones :c)
Thanks and please take a moment to rate as fixya.
Posted on Nov 10, 2008
Missing letters on new keypad
It's must be a problem with the keyboard I think Replace it from the warrenty
Apr 16, 2014 | Acer Aspire Computers & Internet
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
My keyboard wont type
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
b>
Jan 11, 2013 | Samsung N145 Plus 10.1 inch Netbook -...
When you press some letters in the keyboard it writes different characters and leters
I'm not sure how to tell you to correct the problem but the same thing happened to me and really messed with my head until I found out that there are several setting for different languages. The keys apparently mean something different from our language. Go in and reset your keyboard . Some have a drop down box that will let you choose your language. I wish I could tell how to correct it but I don't know what kind of computer is. The Control panel should a place about keyboards and let you change it there.
Gillight
Jun 24, 2012 | Sony VAIO VGP-WKB1 Keyboard
Is videocall is possible on htc salsa
Yes it is possible , but not using your regular phone network . You need to use a third party software ( skype , google chat etc ) and you will be able to chat using that .
Oct 20, 2011 | HTC Salsa Smartphone
Number keys don't work right above letters on keyboard
You have to hold the Fn key, usually blue in the lower left corner of keyboard, for the numbers above the letters to work.
Good Luck,
John Vickers
Sep 18, 2011 | Computers & Internet
Laptop keyboard is typing numbers instead of letters
dude its so easy hehehe just press the function and insert key together and then its already ok!!!!!
a simple tnx is wat i need..:)
Jun 09, 2009 | ASUS 90-A4C1K1000 Keyboard
A letter on my keyboard doesn't work anymore.
it means something is stuck underneath them. like sticky drink or something
Dec 11, 2008 | Computers & Internet
FRENCH LETTERS SYMBOLS
Go to Control Panel and select 'regional and language options'
In the dialogue box that opens, click on 'regional options'
From the drop down menu, choose english (United States)
Click on 'OK'.
Your keyboard should function properly now.
Mar 17, 2008 | Microsoft Wireless Optical Desktop Comfort...
Cleaning the door insides
The door should come apart with a little prying. Be careful because the plastic can break fairly easy. You can look at this description to see what pieces are involved. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503590
Nov 07, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
