Question about Paradyne (6218-A1-200) Wireless Router (6218A1200)
I used the router ip but log in page is not displayed,status ligh is off,
I tried to update my firmware, obviously i used the wrong file. the router now does not respond, no log page is displayed, status light is off. power is on & network is connected.
  • Paradyne Master
  • 6,487 Answers
First thing to do here is to reset the router, To reset it press and hold the reset button for 30 seconds while power is ON then after that unplug the power for 10 seconds and then plug it back in hopefully you can now access the router setup page again, but if still the same router is already bad and needs replacement....
Posted on Nov 10, 2008
Error code 0x8004d112
You also may want to check the status of you router by logging into it and checking the "status" page(IP)
And try to update the firmware..
Jan 24, 2013 | Belkin N Wireless Modem-Router F5D8633au4A
I cannot go on the internet througt my router i have try to resset it, after reseting it it cant give my pc aan ip adres the type of router is dlink dir 600
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 26, 2011 | Computers & Internet
My router seems to work fine with both of my windows 7 computers but, when I enter the ip adress in my browser, the utility does not display correctly and I can't manage the router. Are there updated...
1. check the manual to see if you have the correct IP address to log into the router: that is 192.168.1.1
2. here is the Linksys knowledge base page that will give you more information about your router. firmware updates can be obtained via the router.
3. you may have to set the router to " factory default" using the software that came with the router.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
Will not generate IP address. Internet light does not come on. New modem.
1. power cycle the router
2.
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
Oct 11, 2010 | Westell Wirespeed LiteLine 6110 Modem
I have a WRT54G Linksys Wireless Router and can not VPN or Remote to a server from behind it
It is a passthrough router. you can not create a tunnel using this router. Now if you are using any VPN software to connect to the network then you can try to open the ports on the router.
Reduce the MTU to 1365.
open the ports - 500 , 443-447, 1723, 10000-2000
Try this.
If your router is old then upgrade the firmware of the router.
Apr 23, 2010 | Linksys Wireless-G WRT54G Router
WRT160n version 2....Can log onto internet but it takes 3 or 4 attempts before it will load my homepage...once connected to homepage when I click on another link it takes forever to load and then goes into...
you will need to upgrade the firmware. you have already downloaded the firmware. that file is .bin file . you will not be able to open that file. To upgrade the firmware, you will need to open the set up page of the router.
click here to know more about routers and network
Jan 18, 2010 | Linksys WRT160N Wireless Router
DI-524 status led not blinking
Here are the instructions
  1. Make sure that you have a copy of the latest firmware and it has an *.exe file with it. Because the router's configuration page won't be available, you'll be needing the exe to some sort of force the firmware upgrade procedure.
  2. Unplug everything attached to your router except the power cable and LAN cable connected to your pc.
  3. Configure your TCP/IP with this info: IP:192.168.123.253, Default mask:255.255.255.0, Default Gateway:192.168.123.254 and DNS Server:192.168.123.254 (Use only 1 DNS server). Save this new configuration and reboot your pc.
  4. Unplug the power cable to your router as the pc reboots. When everything is up and running, plug the power cable. The status led will be flashing like crazy. It's normal.
  5. Use the exe file to upgrade your firmware. Make sure that the utility file (exe file) is able to recognize your router or else you won't be able to do a firmware upgrade. Now this may take a while, keep pressing the Refresh button to recognize your router. Once recognized you would see there 192.168.0.1 crash. Once you have this, you can now press the upgrade button.
  6. Wait for a while until the unit finishes the upgrade and once done, I think you have recovered the life of your router from the pits of hell. Hahahaha.
  7. You can now unplug the power of the router and restart your pc, see if everything is doing fine.
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
Nov 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Cannot access the menu to 6218-A1-302 because of wrong update
Hi there, there are so many possibilities to your problem, however the first thing I would do is check underneath your router for the Ip address, if it is not there, then you can check your booklet that came with the router (assuming that you still have it of course)!!
Once you have this, you may then reconfigure / restore the router or alternatively (and firstly), I would check the network key and the type of encryption. The chances are that when you updated the firmware, that the key was also changed! Obviously make sure that the network key you are entering into your computer matches the one within the router for wireless applications, I hope this helps you, Chris
Nov 09, 2008 | Paradyne (6218-A1-200) Wireless Router...
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Green Power light flashing
Hi, Have you tried a hard reset? Your model has a small reset button at the rear between the Internet/WAN connection and one of the antennas (Press for 10 seconds +). Also flashing power led is an indicator of firmware problem which might have been caused by a failed firmware upgrade/update. Instruction on how to correct this problem is also included in the firmware upgrade/update. A more detailed instruction is in the User Manual. With regards to firmware update/upgrade , pls be reminded that firmware is very version specific. To locate the version number, you have to look underneath the unit and download the appropriate firmware from LinkSys website. (http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859878881&packedargs=sku%3D1115416826220&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7888126220B03&displaypage=download) The download is a zip file which you have to extract to a folder. The .bin file plus instructions as well as specific instructions on how to make the power led stop flashing. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Jul 28, 2007 | Linksys BEFW11S4 802.11b Wireless...
Paradyne (6218-A1-200) Wireless Router (6218A1200) Logo
104 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
