Question about Steam Fast SP-660 Iron with Auto Shut-off
Steam Fast SP-660 Iron will not steam with distilled water.
The steamer will turn on and will not steam with distilled water. My husband believes the "water pump" probably does not work. Where can I get parts?
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
Posted on Dec 09, 2008
I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can't I...
Believe it or not, distilled water is quite corrosive, more so when hot. Distilled water doesn't contain any dissolved ions but the water is ionic in nature, the ions of every water molecule tend to dissolve away other elements. Steam generating plants and steam ships as well as steam heating systems treat the water with chemicals to keep the water from eating away the metals of the system and test the chemical makeup several times a day while operating. [I spent 4 years in the Navy on a steam powered ship.]
The same holds true for smaller steam appliances like espresso machines and steamers. A very thin coating of calcium carbonate [limestone] is a good protector but too much makes for inefficiencies and burned up elements.
Somewhere I read that Chrystal Geyser spring water is approximately the correct ion balance for espresso machines and I have been using it for years in my espresso machine. In any case you still need to occasionally de-scale your steamer per the manufacturers recommendations.
Feb 03, 2015 | Rowenta Irons
Floor steamer not getting hot
follow this steps and fix it.
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
    Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
    Dec 17, 2009 | Irons
    My steam iron will not steam. How do I clean it?
    Mix (1 to 5 parts) white vinegar in distilled water and pour into the reservoir. Let sit for an hour or so, then pour out through a coffee filter into a container, then pour back into the iron for another hour. At this point, heat the iron and try the steamer function. The vinegar solution will clean deposits from the steam jets, so don't try to iron anything yet. Keep running solution through until sputtering stops. Wash out the reservoir with distilled water, then refill and steam wash the ports several times to remove the vinegar. If you can get it clean, continue to use only distilled water in the iron.
    Sep 07, 2009 | Irons
    Worn out pad
    I order my replacement press cover pads online at "Sew4Less" - silicone covered pad - they sell for $12.95 /ea plus $5.00 shipping (measures 24"X9") and fits my Steam Press SP660 perfectly.
    Apr 19, 2009 | Steam Fast SP-660 Iron with Auto Shut-off
    How can I prevent my iron from leaving white residue on clothes?
    white residue is caused by lime in your tap water.perfectly safe to drink,but when boiled [as in making steam] the lime is left behind. over timeit builds up in the 'tank' buy a gallon of distilled water from the grocerery-about $1 mix water with white vinegar,50/50 and 'steam it out' once or twice to remove deposits in the resevior.steam it out again w/pure distilled water.try it out on your husbands clothes before you iron your delicates again!!
    Dec 22, 2008 | Panasonic NI-R73NR Iron
    Steam Press sp-660 will not steam with distilled water
    Steamfast brand SP-660 steam press
    contact Top Innovations
    1-800-711-6617
    Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
    Steam Question
    Found the answer. The steam button is built into the handle. Push the button and you have steam.
    Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
    Steam Fast SP-660 Iron with Auto Shut-off Logo
    693 people viewed this question
    Top Steam Fast Irons Experts
    Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
