Question about XION II Mercury (XON102) ATX Mid-Tower Case
Xion II Silver ATX Mid-Tower Case
I am trying to build my first computer. After installing all components, I went to fire it up and the only thing that happened was the mobo lit up and the power button on the case lit up and blinks. After looking over everything I found that the processor was not seated properly. After taking care of that the only additional thing that happens when powering it up is that the main fan attempts to move but stops instantaneously. Any suggestions?
  • bkknowles Nov 10, 2008
    Hi Dave,
    I mean the case fan, my viseo is seperate from the mobo (Intel DX38BT X38 Socket 775 Motherboard), processor is (Intel Pentium Dual Core E2180 2Ghz 1M 800Mhz CPU)
  • David Preston
    David Preston May 11, 2010
    BK,
    By the main fan do you mean the Case fan or the fan on you CPU's heatsink?
    Does your Motherboard have an on board GPU(Onboard Video)?
    Do you have a seperate Video card?
    What is your Motherboard and CPU (Intel/AMD and what type of socket they fit into)
    After I receive this information I should be better suited to assist you.
    Looking forward to helping you.
    Dave
    Sergeant:
  • 207 Answers
There can be several causes for your problem.
So I will walk you through checking the most likely causes.
If you have the manual for your Motherboard it will be useful for reference purposes, otherwise you can find it at intels website with the following link.
http://download.intel.com/support/motherboards/desktop/dx38bt/sb/d9774201_en.pdf
First thing I would check is that ALL of the power connectors are in place and secure. In particular check the 20 pin ATX connector and the two 12V connectors (2 four pin square connectors) right next to the CPU.
I'm not sure if the Aux PCIe connector at the bottom of the board needs to be connected if you have just one Video card. If your Video card has its own power connecter make sure that is attached and secure.
When installing the motherboard there should have been some standoffs you needed to install, more than likely at least nine of them. if any or all of them had a metallic ring around the screw hole then they are important that you have a standoff under it and that it is secured with an electrically conductive screw(Any that came with your case that thread into the standoff should be good).
make sure that that the processor is fully seated and the heatsink (Cooling block if building a water cooled system) is attached properly with a thermal pad/paste.
make sure the fan for the processor is properly attached to the heatsink and its power leads are connected to the CPU fan power connector(On your board the connector is a four pin) the one on the fan may be 3 or 4 pin depending on in it is speed adjustable by the BIOS
there are lockdown latches for your RAM and Video cards, they should come up and fully seat into the notch on the video card and RAM modules.
If you don't have enough RAM modules to fill all 4 slots at once, use the one next to your CPU first then the one the same color as that, then the next one up and its like colored. if you want your RAM. If installing in pairs its important to make sure they have the same specification (Size and timings)
Connect your case fans to their repective pins on the Motherboard.
Connect the power and data cables for your Optical drive(s) and Hard drives.
Make sure the case wiring is attached and properly oriented on their headers
attach the USB & or Firewire(1394) connectors to their respective headers (Be sure not to interchange and attach a 1394 cable to a USB header or vice versa) [That could kill the connectors or fry the Motherboard]
Now I think your ready for a test run.
leave the side panel off and connect everything up and try to boot, If you see a light on the motherboard then thats a good sign that all of the power connectors are properly attached and that the Motherboard is OK.
If you fail to get that light the motherboard may have been damaged when you attempted to power up and the CPU wasn't properly seated
If it attempts to start but shuts down right away, you may have a damaged CPU (Processor) unplug everything, remove the processor(Make sure you discharge any static electricity by placing a hand on the side of you Power supply before touching the CPU) turn it over and look to see if any pins are bent (If so you can straighten them again by using a mechanical pencil. Just pull the lead out and slide the pencil over the pin and adjust to as straight as you can.
Reinstall the processor clean off the old thermal pad/paste from CPU & Heatsink with a Qtip and some rubbing alchohol. Let dry and apply a new thermal pad or paste. If using paste put an amount about the size of a dime over the Core of the CPU if you want to spread it use something other than your finger[oil from skin can affect the pastes conductivity] then reattach Heatsing and fan
and give it another go. If it still does not work, you may have damaged your CPU electrically and it should be replaced(maybe under warranty, since its brand new)
Hope this helps
Dave
Posted on Nov 10, 2008
JUST bought a xion amp solaris pc case and can't figure out how to get the front panel off
At a guess, you'll have to take one side off then look inside, behind the front panel, look for sprung plastic lugs at the bottom, middle and top of the case.
The front may be hooked in one side so there will only be clips for the other.
Sep 12, 2010 | XION Solaris (XON-409) ATX Mid-Tower Case
Im trying to install dell i530 into Xion II case but cant figure out how the power switch led hooks up?
All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located at the very bottom. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. All of the switches and LED pins will be different on different motherboards. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND]. USB and audio will always be the same.
Feb 17, 2010 | XION II Black Pearl ATX Mid-Tower Case
Replacement Door for XION case
Contact support to see if they will give you a replacement, if not, you can check e-bay to see if they have spare parts otherwise you might just need to buy a whole new case.
Dec 17, 2009 | XION II Black Pearl ATX Mid-Tower Case
No display no beep sound
you need to check your memory RAM of your PC. if it is ok or not. try to swap to another pc or tighten it.. cheer ^^
Jul 20, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
We turn the tower on sound like it is booting up but the screen doesn't turn on neither does the keyboard. any suggestions???
Double check that your RAM and video card are seated properly (meaning, take them out and put them back in). If you have multiple sticks of RAM, use only one stick to see if it starts properly.
Reset the CMOS on the mobo and see if that helps.
Apr 15, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
I purchased a zion 2 case and I cant figure out the fan plugs because the plugs are like the ones use for cd burners to power themup
To connect the power cable, just take the 4-pin connector coming from the fan and connect it to any 4 pin connector coming from the power supply. you can then use the 4-pin connector to power a cd/ dvd drive or ATA hard drive
~gnomer
Jan 31, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
HOW DO I CONNECT THE CASING TO THE MOTHER BOARD
what is it you want to do ..install the mother board ? or the wires to connect the usb ect ?
Jan 17, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
XION II Mercury (XON102) ATX Mid-Tower Case Logo
325 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
Farokh Merek
Farokh Merek
JonSnell Electronic
JonSnell Electronic
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
